Civil 3D Forum
2D Polyline/ 3D polyline
3 REPLIES 3
254 Views, 3 Replies
I got this file with 2D polylines as contores.
I want to use it in drawings so I tried to put the elevation to "0".
On the screen it looks like if all segments are at same elevation.
But in properties they have different elevation!
When I change the elvation to "0" in properties the polyline breaks up and jumps in diffrent direction!
In file I am attaching here there is just one polyline but in Working file there are hundreds of polylines behaving this way!
How do I solve this?
3 REPLIES 3
samir_rezk
samir_rezk
Hi @Anonymous
Try using the flatten command to create a 2d polyline at elevation 0 automatically.
also, if they you’re working with 3d polyline, you may want to convert to 2d polylines first by going to the modify tab/expand modify panel/ choose covert 3d to 2d polyline
hope this helps,
Samir Rezk
Technical Support Specialist
Hi @Anonymous
hope this helps,
Samir Rezk
in reply to: samir_rezk
Thanks!
OK, I run:
FLATTEN
CHANGE
And even changing elevation in PROPERTIES...
There are 12000 polylines and it should work...
The issue is how it looks on the screen as I shown in attached file!
Thanks!
OK, I run:
FLATTEN
CHANGE
samir_rezk
samir_rezk
I ran the Flatten Command and it worked for me!
  • I selected the three segments in your drawing,
  • typed Flatten,
  • selected <No> for remove hidden lines!
  • it looks like all three segments are now on Elev. 0!
if you'd like to post your project drawing, I can flatten the contours for you, not sure why it's not working on your end
Samir Rezk
  • typed Flatten,
Samir Rezk
Rail Community
