2014 to 2013 causes FATAL ERROR when drawing has infill grading
We just installed 2014 on two work stations and saved a few Civil 3D files with it. When we try to open these Civil 3D drawings in 2013 they crash with a FATAL ERROR.
The last few lines on the command line shows:
Loading Modeler DLLs.
Modeling Operation Error:
Operation unsuccessful.
This error seems to only happen with drawings that have infill grading. I tested it with a drawing with just poly lines and it worked fine. I then converted those poly lines into feature lines using 2014 and it opened fine in 2013. I then added an infill to the feature line region in 2014 and it crashes in 2013.
Is this a known issue? Is there a fix for it?
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
Link copied
