2 surfaces intersect query - PL elevation
rdavisMX6RG
rdavisMX6RG
I have 2 surfaces (EG & NG). I want to see the line of intersection between them.
Analyze>Ground Data>min dist between surfaces.
Select both and PL drawn at elevation of intersection. (El of 139.755)
Problem I have is on the EG surface the spot at that point is 139.38 & on the NG the spot there is also 139.38
Is the there a reason why the intersection line would be +.375 higher?
GKNIGHT892NE
I would calculate a volume using the two surfaces, the boundary (border might be a better description of the line) of the volume would be the line of intersection between the two surfaces. I think.
