2" Pressure Pipe Run fittings HDPE 3" only
RobertEVs
Advisor Advisor
RobertEVs
I created a PP run using the HDPE 2" pipe size from OTB catalog. Once in I realize that no fittings came in the run due to the fact that HDPE catalogs parts are 3" only. Here is my issue. The only way I can figure on fixing this is to swap every pipe out for a 3" and ADD fittings to each connection. Is there any other quick way to do this short of deleting the entire run including profile and re-creating it with all 3"?
chriscowgill7373
there isnt anyway to add the fittings in during your swap, however, after you swap your parts, you can select the pipe run, and in the ribbon, select your fitting, then click add fitting and then add the fittings where they need to go.  it will add them to to the pipe run. (in 2025 at least)
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
