Communauté
Civil 3D et InfraWorks - Français
Partagez vos connaissances, posez des questions, collaborez sur des idées, et explorez les sujets Civil 3D populaires.
annuler
Affichage des résultats de
Vouliez-vous dire :
Redans d'accrochage
15 RÉPONSES 15
Répondre
Message 1 sur 16
bgalleze
775 Visites, 15 Réponses
Redans d'accrochage
Bonjour tout le monde,
Je vous sollicite pour m'aider à intégrer sur un profil crée par subbassembly composer les redans d'accrochage.
Lorsque le terrain naturel est en pente de 10° les redans d'accrochage sont inévitable
Merci pour votre aide.
voir les 02 images ci dessous.
Étiquettes (1)
15 RÉPONSES 15
Message 2 sur 16
nkiakas
en réponse à: bgalleze
Hi @bgalleze
I am trying to understand your typical section.
  1. Where is the existing ground. Is it the green line?
  2. Is the existing ground, and existing road than have to be improved?
  3. Do you want to prepare a subassembly in SAC (subassembly composer)?
Message 3 sur 16
bgalleze
en réponse à: nkiakas
Yes, the existing ground is the green line. I am looking  for the condition to set in subbassembly composer to createthe catch benches . if the existing ground slope is greater than or equal 10 degrees, the catch benches are unavoidable.
See the image below
 Thank's again for your help.
Message 4 sur 16
nkiakas
Hi @bgalleze
Yes now you are clear.
So the algorithm in SAC will be something like this...
IF surface(existingground).slope>=10% THEN make the steps dx=0.6 and dh=0.2, till you reach the existing surface.
I assume that the slope of the surface will be calculated from the crest and sag, because in between, obviously the surface links slopes will be variable (depends also from the "density" of survey points of your existing ground).
I think this task is doable by using the tool "Loop Geometry" in SAC.
Have you ever use this tool before?
Message 5 sur 16
bgalleze
Thanks for your replay,
I don't get , can you please give me an example.
you can do it an the PKT attached
Message 6 sur 16
nkiakas
Hi @bgalleze
I will prepare something and i will share with you.
I need also some more info
  1. Is all your new road in embankment (in fill)? Or some part will be in cut?
  2. Can you send me please the full picture of typical section above? The one with lot of colors in French language.
Message 7 sur 16
bgalleze
Thank you for your reply Sir,
I Need this an embakment ( fill).
Message 8 sur 16
nkiakas
Hi @bgalleze
If the "steps" should be implemented exatly from point A to pointB,then have to keep either 60cm width or 20cm delta elevation. It can't work with both of them, correct?
Message 9 sur 16
bgalleze
Exactly , I need this one
Message 10 sur 16
manon_puel
Bonjour @bgalleze
Si une des réponses résout votre problème ou vous a permis de mieux le comprendre, voulez vous avoir l'amabilité de cliquer sur le bouton  APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Cela facilitera la navigation de nos utilisateurs qui pourront directement atteindre la solution
Sachez qui si vous avez marqué une réponse comme solution par erreur, vous pouvez annuler ce marquage en cliquant sur le menu du fil (les trois points verticaux) et choisir "pas la solution"
Manon Puel animatrice de la communauté francophone
Message 11 sur 16
bgalleze
Bonjour,
pour le moment je n'ai pas reçu de réponse définitive, une fois reçu je clique sur "Approuver la solution".
Bien Cordialement
Message 12 sur 16
bgalleze
Hello Sir,
What's up about my question.
Best regards
Message 13 sur 16
nkiakas
Hi @bgalleze
I am still trying to implement a working script in SAC, to return the "steps" as points/links, because of course later these steps will be used to create corridor surface for material calculation process i guess
J'essaie toujours d'implémenter un script fonctionnel dans SAC, pour renvoyer les « étapes » sous forme de points/liens, parce que bien sûr, plus tard, ces étapes seront utilisées pour créer une surface de couloir pour le processus de calcul des matériaux, je suppose.
Traduit avec Deepl
Message 14 sur 16
manon_puel
Bonjour @bgalleze
Votre problème a-t-il été résolu? Si oui, pouvez vous nous indiquer de quelle façon pour que cela profite à la communauté, si non, pouvez vous nous dire si vous avez pu essayer les suggestions qui vous ont été faites?
Message 15 sur 16
bgalleze
en réponse à: manon_puel
Bonjour,
Je n'ai as encore résolu mon problème, j'ai essayé avec les suggestions mais je n'ai pas encore le résultat escompté.
Cordialement
Message 16 sur 16
manon_puel
Bonjour @bgalleze, si le problème persiste et que les suggestions ici ne fonctionnent pas, n'hésitez pas à poser votre question sur les forums anglo-saxons!
Bonne journée
Publier dans les forums
