I have my companies layers setup so I can quickly select any layer by typing just a few letters. Every layer from an XREF in the Layers Properties Manager begins with the same letter. I know we used to be able to remove the XREF title for the XREF layers without writing a Lisp routine or deep diving through the REGISTRY, so what gives. Shouldn't this be turned off by default?
I've attached a pic from this forum that appears to show XREF layers without the prefix.
Thanks All
Solved by Jeff_M. Go to Solution.
Thanks for your reply. I just need the XREF name to not show up before the layer name in Layer Properties Manager. That way I can quickly access a layer by typing in the first letter.
I have never seen AutoCAD do that. Perhaps posting in the AutoCAD or AutoCAD customization forums will give better results.
That’s not a solution until you get one in your thread over in the. AutoCAD forum. It looks like they are only confirming what has already been said here.
