V-drain - fixed width, variable depth
I'm trying to create a fixed width, variable depth drain. So for simplicity sake, a fixed 2m wide (at top edges) v-drain that has no depth at Ch:0m, and at CH:20m is 1m deep. So, foreslope and backslope of v-drain varies from flat to 1:1 over the 20m. I've been trying to run a corridor along an alignment (with 1m offsets) using firstly a ditch assembly, then a channel assembly. I've been trying target my profile for the invert of drain and target my alignment offset surface profiles for the top edges of v-drain (to over-ride the fixed slope variables in the assemblies) with no success.
I've poured through a pile of forums and tutorial videos - but nothing to explain what i'm after. Is corridor the correct procedure to achieve what i'm trying to do, or should i use other means?
Alternately is there a method or notation to use in the slope values to allow them to be variable?
Thanks in advance.
Mark.
