System.Windows.Interactivity.dll problem
davidm_adn
davidm_adn
Hi
Some of our WPF dialogs need System.Windows.Interactivity.dll - we ship it, and found it's also in C:\Program Files\Autodesk\AutoCAD 202X\C3D\Dynamo\Core, so it is loaded from there in preference to the one we ship.  I would be OK with that if the one in the C3D folders wasn't 0 bytes in size!  We don't know how it became like that, or whether it was even like that all along.  Has anyone else had an experience with this?
norman.yuan
I am not sure I understand what your question is: are you saying that the System.Windows.Interactivity.dll found in the folder of "...\C3D\Dynamo\Core\" is 0 bytes in size? Does it happen in only one computer/only one C3D version, or all C3D versions/all computers of yours/your users?
I have 2 computers with various versions of C3D installed, the sizes of System.Windows.Interactivity.dll are all not 0 bytes.
Norman Yuan
Drive CAD With Code
davidm_adn
yes that's correct.  Across our team, I think 4 of us have reported a file size of zero, and the other 3 have the DLL which looks correct (approx 55kb)
Jeff_M
Weird, on my machine:
C3D 2022 has that dll with a size of 55kb
C3D 2023 has that dll with a size of 0kb
C3D 2024 does not have that dll.
I would try renaming it and see if Dynamo still works, if you even use it.
Jeff_M, also a frequent Swamper
davidm_adn
thanks Jeff that's interesting to know, and reassuring that it's not us somehow causing that DLL to go to 0 bytes in size!
We don't use dynamo; the problem really for us is that because the file is 0 bytes, we can't show our application dialogs in Civil 3D.  I'm slightly anxious about telling our users that the workaround is to delete or rename a DLL which isn't ours but that does seem like the only option at the moment!
