surface Offset on the sections sample lines
alexjuinamt
New Member
New Member
alexjuinamt
New Member
New Member
The following code works if the surface is of the CorridorSurface type, if a TinSurface is selected, an error occurs, what is wrong in the code?
Private Function ObterLargurasSecoes(alinID As ObjectId, sufID As ObjectId, estaca As Double, larguraMax As Double, ByRef LE As Double, ByRef LD As Double) As Boolean
    ' Documents
    Dim acadDoc As Document = acApp.DocumentManager.MdiActiveDocument
    Dim civilDoc As CivilDocument = CivilApplication.ActiveDocument
    Dim ed As Editor = acadDoc.Editor
    Using tr2 As Transaction = acadDoc.TransactionManager.StartTransaction
        ' Get the alignment
        Dim alin As Alignment = tr2.GetObject(alinID, OpenMode.ForRead)
        ' Create a group of points with the external vertices of the sample line
        Dim grupoDePontos2D As New Point2dCollection()
        ' Define the coordinates for the left side
        Dim esteLE As Double = Nothing
        Dim norteLE As Double = Nothing
        alin.PointLocation(estaca, -larguraMax, esteLE, norteLE)
        Dim pontoLE As New Point2d(esteLE, norteLE)
        grupoDePontos2D.Add(pontoLE)
        ' Define the coordinates for the right side
        Dim esteLD As Double = Nothing
        Dim norteLD As Double = Nothing
        alin.PointLocation(estaca, larguraMax, esteLD, norteLD)
        Dim pontoLD As New Point2d(esteLD, norteLD)
        grupoDePontos2D.Add(pontoLD)
        ' Create a temporary sample line group
        Dim slGrupID As ObjectId = SampleLineGroup.Create("AlX_x-x_GrLixo " & alin.Name, alinID)
        Dim slGrup As SampleLineGroup = tr2.GetObject(slGrupID, OpenMode.ForWrite)
        ' Create a sample line
        Dim SlID As ObjectId = SampleLine.Create("AlX_x-x_slLixo", slGrupID, grupoDePontos2D)
        ' Get the section sources available for the SampleLineGroup and choose the surface
        Dim sectionSources As SectionSourceCollection = slGrup.GetSectionSources()
        For Each sectionSource As SectionSource In sectionSources
            If sectionSource.SourceId = sufID Then
                sectionSource.IsSampled = True
                Exit For
            End If
        Next
        ' Get the sample line
        Dim sl As SampleLine = tr2.GetObject(SlID, OpenMode.ForRead)
        ' Get the collection of sections in the sample line; there will be only one
        Dim slIDs As ObjectIdCollection = sl.GetSectionIds()
        ' Get the section
        Dim secao As Autodesk.Civil.DatabaseServices.Section = tr2.GetObject(slIDs(0), OpenMode.ForWrite)
        Try
            LE = secao.LeftOffset
        Catch
            LE = Nothing
        End Try
        Try
            LD = secao.RightOffset
        Catch
            LD = Nothing
        End Try
        ' Do not commit to avoid creating the auxiliary sample line
    End Using
    ' Return false if no values are found
    If LD = Nothing And LE = Nothing Then
        Return False
    Else
        Return True
    End If
End Function
Replies (7)
essam-salah
what is the error type and error message you get?
alexjuinamt
New Member
New Member
I get the error: 'System.InvalidOperationException'. I will attach the images where the error occurs and another that does not occur.
Jeff_M
This appears to be the error thrown when there is no portion of the section on the right side.
alexjuinamt
New Member
New Member
Yes, it seems to be the same error, however there is a section of the surface on both sides. The following image is the section view generated by the code.
essam-salah
sadly, as VS decompiled code below it shows that there is two types of sections that don't have Left/Right Offsets properties,
  public unsafe double LeftOffset
    get
      //IL_003b: Expected I, but got I8
      //IL_0053: Expected I4, but got I8
      //IL_005e: Expected I, but got I8
      //IL_0074: Expected I, but got I8
      //IL_0076: Expected I8, but got I
      //IL_0095: Expected I4, but got I8
      //IL_00dc: Expected I, but got I8
      string message = "LeftOffset is not supported by current Section.";
      byte b = (isSectionSupportOffsetElevation() ? ((byte)1) : ((byte)0));
      if (0 == b)
        throw new InvalidOperationException(message);
      AeccDbSection* impObj = GetImpObj();
      long num = *(long*)(*(long*)impObj + 3544);
  [return: MarshalAs(UnmanagedType.U1)]
  private unsafe bool isSectionSupportOffsetElevation()
    //IL_0017: Expected I, but got I8
    bool result = true;
    AeccSectionSource.SectionDataType sectionDataType = ((delegate* unmanaged[Cdecl, Cdecl]<IntPtr, AeccSectionSource.SectionDataType>)(*(ulong*)(*(long*)impObj + 3400)))((nint)impObj);
    if (sectionDataType == (AeccSectionSource.SectionDataType)4 || sectionDataType == (AeccSectionSource.SectionDataType)8)
      result = false;
    GC.KeepAlive(this);
    return result;
public enum SectionSourceType
  TinSurface,
  Grading,
  Corridor,
  CorridorSurface,
  PipeNetwork,
  Material,
  GridSurface
essam-salah
so if you can show us in a pic what exactly what do you want to get/achieve some one might be able to help,
for example, if you want that section start/end points as offsets (from assembly CL) simply we can use props like  section.StartPoint or section.SectionPoints to get the end points as XY coordinates then use profile view function called profileView.FindStationAndElevationAtXY  to get station/offset.
essam-salah
now it make sense cuz corridor section has created from an assembly that have Left/Right props, any other section that created from Non-Corridor surface (so to speak) no nothing about the corridor nor the used assemblies
