Subassembly Composer Help
waycello
waycello
Hi everybody,
I have an issue with sac. Project is an alternative daylight which is checking if there is any other surface intersecting before every daylight line is created. The main aim is targeting multiple (actually 2) surfaces with one daylight. Problem is in the last desicion. On the true side it must be start with P9 (from point - P9) and the false side must be started with P15 (from point - P15). P9 can be choosen in the true side but p15 doesnt exists. Can any body solve this problem please. Pictures and my pkt file is in the attachment.
Thanks a lot.
Veysel.
Dexterel
easy fix, just upload your pkt
waycello
Thx, @Dexterel.
Actually i forget to delete the message. Problem was an if decision.
Parameters were forcing the decision to false side while the problem i mentioned was in true side.
So it is solved.
But pkt become garbage because of civil 3d limitations.
Civil 3d says its infinite loop when u try to target daylights to each other.
