Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Start and end point of alignment API Visual Basic . NET
3 REPLIES 3
673 Views, 3 Replies
I need to determine and extract the coordinates of the start and end point of the alignment.
Can someone help me with an example .net code.
Thank you very much.
Best regards.
Mauro Vega
AutoCAD Civil 3D 2018.1
Intel Core i7-6700HQ CPU 2.6 GHZ
32 GB RAM 2133 MHz
NVIDIA Quadro M3000M
Windows 10 Pro 64 Bits
Tags (1)
3 REPLIES 3
Jeff_M
I don't do VB, so no example. However, the Alignment Object inherits from the AutoCAD Curve object, so it's properties can be used on the alignment. A Curve object has the StartPoint and EndPoint properties which is what you are looking for.
Jeff_M, also a frequent Swamper
sybold
this should get you on your way,
            '' autocad
            Dim doc As Document = Core.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim trans As Transaction = db.TransactionManager.StartTransaction
            '' civil
            Dim cdoc As CivilDocument = CivilApplication.ActiveDocument
            '' select alignment
            Dim promptentop As New PromptEntityOptions(vbLf + "select alignment")
            promptentop.SetRejectMessage("no alignment")
            promptentop.AddAllowedClass(GetType(Alignment), True)
            promptentop.AllowNone = False
            Dim promptentres As PromptEntityResult = ed.GetEntity(promptentop)
            If promptentres.Status <> PromptStatus.OK Then
                ed.WriteMessage(vbLf + "error, no alignment")
            Dim alm As Alignment = trans.GetObject(promptentres.ObjectId, OpenMode.ForRead)
            '' alignment stuff
            Dim start As Point3d = alm.StartPoint
in reply to: sybold
Hello Sybold,
Thank you very much, you are very kind.
This was just what I needed.
Best regards.
Rail Community
