Setting featureline styles in Corridor: FeatureLineCodeInfo
joantopo
Mentor Mentor
joantopo
Hi.
I want to set all feature lines styles (about codes) from Corridor:
In Corridor Members there is "FeatureLineCodeInfo" but it hasn´t any member to get/set feature line styles.
It only has the properties:
  Name Description
Public propertyCodeName
Gets the code name.
Public propertyCorridorId
Gets the ID of the parent Corridor.
Public propertyIsConnectObsolete.
Gets or Sets whether the feature line connects to multiple points which share the same code in the same applied assembly.
Public propertyIsConnected
Public propertyIsDrawObsolete.
Returns true if the feature line is drawn.
Public propertyPayItems
Gets or Sets the pay item list.
Is there any way to do this?
Thanks.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Civil3DReminders
Those should be being pulled from the code set style, why not modify the code set, turn off all baselines/regions, and then turn the corridor regions back on?
joantopo
Well, it could be a way but I don´t want to change the code set style. I want to change the feature line style within the corridor.
Jeff_M
Joan, As Christopher noted, the Featureline Styles used by the corridor are dictated by the CodeSet Style in use. To change them in the corridor, you must change the CodeSet style.
Jeff_M, also a frequent Swamper
