Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Replace Pi Point from FeatureLine
1 REPLY 1
ahernandezmendez
129 Views, 1 Reply
Hi, I'm trying to replace a pi point with the same one but changing the elevation, this is because the Z attribute of a Point3d is read only.
Most of the time it does fine, but sometimes it throws the following exception.
ArgumentException("The specified point is before or on the start point of feature line")
I understand the message, but I'm not able to see why it does it occasionally.
Here is the point where the code fails:
try {
using Transaction tr = CivilDB.GetDatabase().TransactionManager.StartTransaction();
FeatureLine flMod = fl.ObjectId.GetObject(OpenMode.ForWrite) as FeatureLine;
Point3d pointModify = new Point3d(point.X, point.Y, newElevation);
//RemovePointFromFL(ref flMod, point);
flMod.DeletePIPoint(point);
flMod.InsertPIPoint(pointModify);
coords[direction] = pointModify;
fl = flMod;
tr.Commit();
catch (System.Exception ex) {
UtilsServices.WriteCoordinates("Error point: ", pointFl.X, pointFl.Y, pointFl.Z);
CivilDB.Write("Error in Fl: " + fl.Name + "|| Point in position " + direction + " not typed correctly.");
CivilDB.Write("Civil3D failed due to : " + ex.Message);
I have to comment that CivilDB is a class of its own where I encapsulate several methods.
Thank you very much
Best regards.
Tags (2)
Labels (1)
1 REPLY 1
hippe013
in reply to: ahernandezmendez
You should use the 'SetPointElevation' method of the featureline.
Rail Community
