renumber cogo points
cilate4044
Observer
cilate4044
Observer
Observer
This AutoLISP function is designed for use in AutoCAD, specifically with Civil 3D. It allows the user to renumber a set of COGO (Coordinate Geometry) points in the drawing. The points can be sorted according to different criteria before renumbering
I use chat gpt but it is not working
(defun c:RenumberPoints ( / c3dApp c3dDoc c3dPoints pts startNum newNum sortedPoints obj sortOption lineObj distList minNum maxNum defaultStartNum)
; Load Visual LISP library
(vl-load-com)
; Call AutoCAD application
(setq c3dApp (vlax-get-acad-object)) ;; Get AutoCAD application
; (setq c3dDoc (vla-get-ActiveDocument c3dApp)) ;; Get the active document
; Access points within Civil 3D using vla-get-CogoPoints from the AutoCAD document
; (setq c3dPoints (vla-get-CogoPoints c3dDoc)) ;; Access points in the active document
; Ensure points are selected
(setq pts (ssget "_:L" '((0 . "AECC_COGO_POINT")))) ;; Select only COGO points
(if pts
(progn
; Extract point numbers
(setq sortedPoints
(mapcar
(lambda (e)
(setq obj (vlax-ename->vla-object e))
(list e (vla-get-PointNumber obj)))
(vl-remove-if 'null (mapcar 'ssname (list pts)))
; Calculate the smallest and largest point numbers
(setq minNum (apply 'min (mapcar 'cadr sortedPoints)))
(setq maxNum (apply 'max (mapcar 'cadr sortedPoints)))
(setq defaultStartNum (+ maxNum 1)) ;; Suggested starting number
; Display information window
(princ (strcat
"\nSelected Points Info:\n"
" Smallest Point Number: " (itoa minNum) "\n"
" Largest Point Number: " (itoa maxNum) "\n"
" Suggested Starting Number: " (itoa defaultStartNum) "\n"
; Input starting number
(setq startNum (getint (strcat "\nEnter the starting number for renumbering [Suggested: " (itoa defaultStartNum) "]: ")))
(if (null startNum) (setq startNum defaultStartNum))
; Choose sorting method
(setq sortOption (getstring "\nChoose sorting method: [X/Y/Line]: "))
(cond
; Sort points by X coordinate
((equal sortOption "X")
(setq sortedPoints
(vl-sort
sortedPoints
'(lambda (a b) (< (vlax-get (vlax-ename->vla-object (car a)) 'Easting)
(vlax-get (vlax-ename->vla-object (car b)) 'Easting)))
;; Sort points by Y coordinate
((equal sortOption "Y")
(setq sortedPoints
(vl-sort
sortedPoints
'(lambda (a b) (< (vlax-get (vlax-ename->vla-object (car a)) 'Northing)
(vlax-get (vlax-ename->vla-object (car b)) 'Northing)))
; Sort points by a specific line
((equal sortOption "Line")
;; Select line
(setq lineObj (vlax-ename->vla-object (car (entsel "\nSelect the line or polyline to sort points by: ")))))
(if lineObj
(setq sortedPoints
(vl-sort
(mapcar
(lambda (item)
(setq obj (vlax-ename->vla-object (car item)))
(setq coords (vlax-get obj 'Coordinates))
(list (car item)
(vlax-curve-getDistAtPoint
lineObj
(vlax-curve-getClosestPointTo lineObj coords))))
sortedPoints
'(lambda (a b) (< (cadr a) (cadr b)))
(princ "\nNo line or polyline selected.")
; Handle invalid sorting option
(T (princ "\nInvalid sorting option. Please choose X, Y, or Line."))
; Renumber the points
(setq newNum startNum)
(foreach item sortedPoints
(vla-put-PointNumber obj newNum)
(setq newNum (1+ newNum))
(princ "\nRenumbering completed.")
(princ "\nNo points selected.")
(princ)
Accepted solutions (3)
Replies (10)
Jeff_M
@cilate4044 the following was tested with the X sort option. The Y should work, not sure about the Line option...n more time for testing. Removed ....found a bug
cilate4044
Observer
Observer
sorry I am not programmer
the error appear : syntax error
Jeff_M
@cilate4044 This one works...mostly. A check should be added to be sure the starting number will be greater than the highest number in the dwg.
;;------------=={ SelectionSet -> VLA Objects }==-------------;;
;;  Converts a SelectionSet to a list of VLA Objects          ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  ss - Valid SelectionSet (Pickset)                         ;;
;;  Returns:  List of VLA Objects, else nil                   ;;
(defun LM:ss->vla (ss / i l)
  (if ss
    (repeat (setq i (sslength ss))
      (setq
	l (cons	(vlax-ename->vla-object (ssname ss (setq i (1- i))))
		l
(defun c:RenumberPoints	(/	      c3dApp	   c3dDoc
  (vl-load-com)
  (if pts
    (progn
      (setq sortedPoints
	     (mapcar
	       '(lambda	(e)
		  (list e (vlax-get e 'Number))
	       (LM:ss->vla pts)
      (setq defaultStartNum (+ maxNum 10000))
      ;;the program will fail when a duplicate number is encountered so set to number higher than any in the drawing
      (princ (strcat
	       (itoa minNum)
	       "\n"
	       (itoa maxNum)
	       "\n"
	       "\n"
      (setq startNum
	     (getint
	       (strcat
      (if (null startNum)
      (setq sortOption
      (cond
	 (setq sortedPoints
		(vl-sort
		  sortedPoints
		  '(lambda (a b)
		     (<	(vlax-get (car a) 'Easting)
			(vlax-get (car b) 'Easting)
	 (setq sortedPoints
		(vl-sort
		  sortedPoints
		  '(lambda (a b)
		     (<	(vlax-get (car a) 'Northing)
			(vlax-get (car b) 'Northing)
	((equal sortOption "L")
	 ;; Select line
	 (setq lineObj
		  (car
		    (entsel
	 (if
	   lineObj
	    (setq sortedPoints
		   (vl-sort
		     (mapcar
		       '(lambda	(item)
			  (setq obj (car item))
			  (setq coords (vlax-get obj 'Location))
			  (list	(car item)
				  lineObj
		       sortedPoints
	   ;;if this is hit should abort the renumbering else it will just use the existing order
	(T
	 (princ
	(vlax-put obj 'Number newNum)
  (princ)
cilate4044
Observer
Observer
the code is working fine but sometimes the ordinary is not correct and can you add regen to update screen after use lisp
thank you
Jeff_M
Please describe what you are seeing vs what you are expecting. A screen capture would help.
For the Regen:
      (command "REGEN") ;;<<<< Insert this line
cilate4044
Observer
Observer
the ordinary not correct (I test lisp for x and polyline )
cilate4044
Observer
Observer
when I asked chatgpt answer:
I believe the reason the code is sorting the points based on the point number rather than the selected options is that the points are initially extracted and sorted by their number before any sorting option is applied.
Note the code:
lisp
(setq sortedPoints
       (mapcar '(lambda (e) (list e (vlax-get e 'Number)))
               (LM:ss->vla pts)))
The above code extracts the points and sorts them based on the point number only. Therefore, when applying any sorting option, the appropriate sorting has not been applied because the points have already been sorted by their numbers.
To fix this, you can modify the code to directly extract the coordinates and apply the sorting based on the chosen options before sorting the points.
Jeff_M
@cilate4044 chatGPT is wrong. That bit of code is not doing any sorting, it is merely collecting the point numbers of the selected points so the tool can get the lowest and highest point numbers. One issue was with getting the sort option. Using getstring would fail if you entered x expecting the X option. Use getkword instead to avoid that problem:
      (initget 1 "X Y Line")
      (setq sortOption
	     (getkword "\nChoose sorting method: [X/Y/Line]: ")
which also will require the cond statement for Line to actually say Line (like you originally had).
ANother issue comes up when you use the line option, select a poyline which runs through the points. The vlax-curve-getclosestpointto function fails to work as expected. If  you select a line it works just fine.
Numbers 1-5 where sorted by X, 6-10 sorted by a straight line.
cilate4044
Observer
Observer
thank you very much
cilate4044
Observer
Observer
"This Lisp can handle polyline, but it changes all the numbers in the drawing instead of just the selected points. It doesn't allow choosing the starting number or selecting the direction of the polyline to renumber (beginning or end)."
