Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Profile , View Frame & Plan and Profile Sheets for multiple alignments
4 REPLIES 4
751 Views, 4 Replies
I have nearly 100 or more alignments in my drawing.
Need to create profile, View frames and plan profile sheets for each and every alignment.
So this is very time consuming and need to develop custom command to do
  1. Create profiles for all alignments using same settings
  2. Create view frames  for all alignments using same settings
  3. Create plan profile sheets  all alignments using same settings.
Is there any method to do this using civil 3d commands.
If not I know I have to using one of Civil 3D API.
I have some basic programming experience but not with Civil 3D APIs.
So pls give some directions
4 REPLIES 4
Civil3DReminders_com
Everything you have on your list should be doable except for the view frames. You'll want to create your own tools that do the same things.
You'll want to search in https://www.google.com/ for sample code. I'd suggest using a search that starts with "Civil 3D API .NET" and then what you are looking for. You should be able to find code samples that way.
The Civil 3D Developer's Guide may be found here: http://docs.autodesk.com/CIV3D/2016/ENU/API_Reference_Guide/index.html
I usually do a search in the browser to find objects and then all of the properties and methods are found there.
The SincPac has some sample code, which is a great starting point: http://info.quuxsoft.com/SincpacC3D_source.aspx
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
in reply to: Civil3DReminders_com
Dear Sir
Is it possible to create Plan & Profile Sheets for multiple view frame groups at once?
Regards
Chamara
I wasn't able to find a way through the Civil 3D API.
It looks like you would need to create the layouts and viewports via the AutoCAD API.
Civil Reminders
Rail Community
