Need A Smart Table for Alignment Angles (Alignment has no curves)
sstoreyKQ6MP
sstoreyKQ6MP
We have several alignments that represent water pipes and because there are so many bends and deflections the smart point of intersection labels cover too much of the plan space, so the client wants to move the information to a table. Is there a way to keep the info "smart" so that if the alignment changes the table will update as well? The current alignment tables won't seem to work because there are no actual curves, just PI's, and we need the delta angle of each bend. Is there a way to get that Point of Intersection label data into a table somehow? Thanks!
Jeff_M
Add a small radius curve, say 0.5' or less, then set the table to label only the pi angle for curves:
This will have a minor impact on the line lengths...less than the size of any fittings.
Jeff_M, also a frequent Swamper
Jeff_M
The table style:
sstoreyKQ6MP
Thanks Jeff! Going to give this solution a go.
