Modify Sample.dvb File To Export/Import Select Pipe/Structure Properties
I have seen posts on the forum for using the Sample.dvb file that comes with everyone's C3D to export information about a pipe networks pipes and structures to Microsoft Excel. I am hoping that someone can help me modify this sample.dvb file to export some slightly different information from pipe networks. Currently, the file exports a big long list of information about the pipes/structures and most of it is not important for the application I am hoping to use it for. This sample file seems like a great starting place, but I am beginner level at VBA and am not sure how to incorporate the changes I would like to see. A sample excel file for the properties that I would like to see exported from the command is attached. I have also attached a DWG file where I have set up a simple pipe network to analyze. My hope is to be able to export the information and then be able to make changes to the excel file and then import the updated values back into C3D.
Thank you in advance for your help, and I would be more than happy to learn about editing these macros.
