Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
LISP to extract cogo point description and elevation to fill out block attribute
1 REPLY 1
phil_planright
570 Views, 1 Reply
Has anyone got a lisp that enables you to select cogo points and then based on their descriptions fill out attributes in a block.
ie.
cogo point 1 (description="aaa 123" elevation="100.25")
cogo point 2 (description="bbb 123" elevation="300.50")
I the need this to fill out a block where the attribute "aaa" is filled out as "100.25" and "bbb" is filled out as "300.50". I would also like if possible to extract the second part of the description ("123") to fill out another attribute in the block.
I have a lisp that can extract parts of the cogo point to text, but that is as far as i have gotten with it.
At the moment we are manually filling out the blocks, but this becomes quite tedious when there are up to 50+ blocks to fill out.
Hopefully someone can help. Thanks.
1 REPLY 1
hippe013
in reply to: phil_planright
Are you just looking into setting the blocks attributes?
(defun testSetAtt (block aaaTagString aaaValue bbbTagString bbbValue)
  (setq atts (vlax-safearray->list (vlax-variant-value (vlax-invoke-method blk 'GetAttributes))))
  (foreach att atts
    (cond
      ((= (vlax-get-property att 'TagString) aaaTagString)(vlax-put-property att 'TextString (vl-princ-to-string aaaValue)))
      ((= (vlax-get-property att 'TagString) bbbTagString)(vlax-put-property att 'TextString (vl-princ-to-string bbbValue)))
you
Rail Community
