Lisp for creating Multileader from object Extended Data
TourajM
Message 1 of 19
TourajM
Hi Dears,
I am a Land Surveyor, and in our daily work, we generate several CAD files. For example (File 2026-org.dwg) has lines, polylines, and blocks with attributes. Most of these objects have Extended Data, and we need to project these Data on the map; we manually use Multileader as shown in (file 2026.dwg). I am looking for a program or a lisp that can automate this progress and save much of our time. I would highly appreciate it if anyone could help me in this matter.
Best Regards,
Replies (18)
Message 2 of 19
pbejse
@TourajM wrote:
Hi Dears,
I can see that the application name is "TrimbleName" but can't see any information that pertains to the diameter and "D" value from the XDATA, except of course Z-values on some of the entities which can be obtain without XDATA.
Guess you just wanted to label the elements via lisp ? Am I missing something here? in Civil 3D perhaps?
Message 3 of 19
TourajM
Thank you for the replay. The application name "TrimbleName" is because we process and create CAD files from our Survey Data with Trimble Business Center software. If you select any polyline or line and check the properties in the Extended Data tab, you will find the relative information such as Dia and Depth. as a sample of how I need to project or, as you said, Label, I shared File name 2026. DWG.
Message 4 of 19
TourajM
For more
explanations, I have attached two screenshots.
Message 5 of 19
pbejse
Sure enough it's in Civil 3D,
Not sure if with Civil 3D Enabler that information can be access thru Vanilla AutoCAD.
Message 6 of 19
TourajM
I Hope Someone Can help me with this.
Message 7 of 19
hosneyalaa
@TourajM
this is .dll file , iam need time to change it , for you
Command: NETLOAD
Command:  TESTShortestNetworkPath
Message 8 of 19
TourajM
Thanks a lot,
I’m very grateful for your time and support.
Message 9 of 19
hosneyalaa
TRY
@TourajM
Message 10 of 19
TourajM
Dear hosneyalaa, I don't know how to thank you. This dll works perfectly and is amazing. If it is not too much to ask, is it possible to Modify it to select the blocks as well? We have a lot of Blocks, such as Trees, street lamp posts, etc, with Extended Data. Also, can we change the Command: TESTShortestNetworkPath to something shorter or simpler to be remembered?
Again I appreciate your time and support.
Message 11 of 19
TourajM
As a sample of blocks in the drawing, I attached a file.
Message 12 of 19
hosneyalaa
@TourajM
try
Message 13 of 19
TourajM
Thank a lot. this is exactly what I needed. well done.
Message 14 of 19
Bart_Dheere
It seems that this feature is nog working for me.
I put the dll-file on my local pc.
Netload asks me to select the dll. So far so good.
But the command to label is not working.
regards
Message 15 of 19
jklinkeB8EEG
This tool seems amazing, is it something you would be willing to share as the .dll code?
Message 16 of 19
Jeff_M
@jklinkeB8EEG the dll was posted in a RAR by @hosneyalaa in message 12.
Jeff_M, also a frequent Swamper
Message 17 of 19
jklinkeB8EEG
I was actually wanting to see how this .dll was coded in .NET, if they were willing to sare.
Message 18 of 19
TourajM
Sorry for the late response; I was sick for 2weeks with Corona. The command is: EXTENDED_DATA
Message 19 of 19
TourajM
Thank you for your reply.
