Label with Oval Border and Background Mask
Civil 3D 2010
I might be missing this but I would like an oval around my curve label.  I can use a block, but I would also like to have the background mask on as well.
See attachment: I turned on the rounded rectangular with the background mask on, but I would like my oval to do that instead.
I would think you need to use a block since the oval isn't a native option. Since you want a mask, you could use a solid hatch with 255,255,255 as the color, then have them organized (draworder) in the style to move the text to the front.
Just a non-coded approach...
That's a good idea.  But when I do that I can't see what the text says on screen.  See attached.
peterfunkautodesk
Add a new text element after you add the ellipse block. You might also try a wipeout inside of the block, but make it smaller than the ellipse (or just show the wipeout frame for the graphics
Cheers,
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
What is the rounded rectangular and how do you turn it on? ACAD 2019 -Thanks
