Label Style Text Component Editor
CADUSER2009
Message 1 of 8
CADUSER2009
Does anyone know if "Justification" in the Text Component Editor has been exposed in .NET? I can't find a method for it. See attached screen grab.Screen grab.jpg
Replies (7)
Message 2 of 8
augusto.goncalves
What about Text Attachment property?
LabelStyleTextComponent.Text.Attachment.Value
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 3 of 8
CADUSER2009
Thanks for the reply Augusto. I did try that, but it changes the alignment of the text attachment not the justification of the text itself. See screen grab below. It's a real head scratcher.Screen grab2.jpg
Message 4 of 8
augusto.goncalves
Indeed, you're correct.
Now each Label has a SubEntity property that returns a collection, each subentity has a SetTextComponentJustificationOverride that could work. I'll only have time to try it tomorrow... in case you can try it earlier.
Augusto Goncalves
Message 5 of 8
CADUSER2009
Thanks Augusto. I've given that a go as well. If I remember correctly I could only apply "SetTextComponentJustificationOverride" on an instance of a CogoPoint not the PointLabelStyle as a whole. But it was a week ago so I might be wrong. Give it a go. I might have missed something. Thanks mate.
Message 6 of 8
Civil3DReminders_com
I think the last time I looked at it Civil 3D used the mtext codes for that, but I could be wrong.
http://www.cadforum.cz/cadforum_en/text-formatting-codes-in-mtext-objects-tip8640
It was either that or Civil 3D used them when added to the label.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 7 of 8
CADUSER2009
Hehe. I tried that as well. Thats how I got multiline to work with the "\P" control key. But the alignment "\A" control key doesn't work. Even if it did, it controls the vertical alignment (bottom, center, top) not horizontal alignment (left, center, right). I get the feeling this hasn't been exposed in .NET yet. Ta.
Message 8 of 8
augusto.goncalves
Indeed, no luck with this SetTextComponentJustication... sorry.
Augusto Goncalves
