insert survey points in surveydatabase to drawing via API/.NET
kenleung19862002
kenleung19862002
I would like to know if there ways to insert survey points in surveydatabase to drawing via API/.Net
hosneyalaa
hi
can you see
Jeff_M
To expand on what @hosneyalaa shared, the SurveyNetwork COM object has the AddPointsToDrawing method:
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/AeccXSurveyLib__IAeccSurveyNetwork.h...
Jeff_M, also a frequent Swamper
TerryDotson
can you see
Ah yes, COM, introduced in 1993.  Hot stuff back then, not so much anymore.
