Announcements
Identify Alignment Movement
alexisgacia
alexisgacia
Good day.
Need you help on the project that I working. I'm working on creating an objects that follow on alignment object. When I going to adjust the alignment it follows the objects.
I cannot find the right code to be use in C#.
What I'm planning is when I create an Alignment I will create a polyline object base on the offset of the alignment. When I going to move or stretch the alignment it will follow the polyline.
Thanks in advance.
hippe013
Why wouldn't you just use an offset alignment? No need to re-invent the wheel.
essam-salah
hi @alexisgacia
have you tried to hook a method to myAlignment.Modefied event?
alexisgacia
Never tried yet. How can I check the properties and methods available for the objects? I'm still new in C# and still learning. Thank you.
alexisgacia
I already made the alignment offset. But they asked me to use polyline because alignment is heavy.
