- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day.
Need you help on the project that I working. I'm working on creating an objects that follow on alignment object. When I going to adjust the alignment it follows the objects.
I cannot find the right code to be use in C#.
What I'm planning is when I create an Alignment I will create a polyline object base on the offset of the alignment. When I going to move or stretch the alignment it will follow the polyline.
Thanks in advance.
