Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
How to see if a Point Label has been moved to Dragged State
6 REPLIES 6
tcorey
971 Views, 6 Replies
Hello. Here's a rooking LISP question.
I can access a COGO Point with Visual LISP. It shows the label style, but there doesn't appear to be a way to evaluate the label. If the label is in dragged state, I want to be able to record the label location, hoping that, once written out to csv, I can import to another drawing, with edits intact.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
6 REPLIES 6
Jeff_M
in reply to: tcorey
You can do this using the .NET API but not COM.
Jeff_M, also a frequent Swamper
tcorey
in reply to: Jeff_M
Thanks, Jeff. I had a hunch this might be the case. Bummer.
Tim Corey
Redding, CA
Jeff_M
in reply to: tcorey
@tcorey Tim, I've been messing around with this and have this working:
;;Select a Point
(setq pt (car (entsel "Select point:")))
;;Check if it is dragged
(setq test (islabeldragged pt))
;;get the label location
(setq loc (pointlabellocation pt))
;;set a new label location, returns T if successful
(setq moved (pointlabellocation pt '(4332.33 3941.84 648.374)))
The results running in the VLIDE:
_$ (setq pt (car (entsel "Select point:")))
<Entity name: 2e6775cf890>
_$ (setq test (islabeldragged pt))
T
_$ (setq loc (pointlabellocation pt))
(4288.39 3899.92 648.374)
_$ (setq moved (pointlabellocation pt '(4332.33 3941.84 648.374)))
T
I will be cleaning up the code and compiling it to post soon.
Jeff_M
in reply to: Jeff_M
Attached is a ZIP with the compiled assembly. Be sure to Unblock the ZIP after downloading, extract the DLL file to a location you can later find it. Netload it into C3D, then the 2 lisp functions will be available.
(IsLabelDragged ent)
(PointLabelLocation ent)
(PointLabelLocation ent pt3d)
where ent must be the ENAME of a CogoPoint and pt3d must be a list of 3 doubles:  (x y z)
Here's the code for anyone that would like to see it:
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.Civil.DatabaseServices;
namespace C3DLispTools
    public class CogoPointFunctions
        [LispFunction("IsLabelDragged")]
        public object IsLabelDragged(ResultBuffer rbfArgs)
            try
                Database db = Application.DocumentManager.MdiActiveDocument.Database;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    var arInputArgs = rbfArgs.AsArray();
                    TypedValue tv = (TypedValue)arInputArgs.GetValue(0);
                    ObjectId objId = (ObjectId)tv.Value;
                    CogoPoint pt = objId.GetObject(OpenMode.ForRead) as CogoPoint;
                    if (pt == null)
                        return "Error: Not a CogoPoint!";
                    return pt.IsLabelDragged;
            catch
                return LispDataType.Nil;
        [LispFunction("PointLabelLocation")]
        public object PointLabelLocation(ResultBuffer rbfArgs)
            object retval = null;
                if (pt == null)
                    retval = "Error: Not a CogoPoint!";
                else if (arInputArgs.Length == 1)
                    retval = pt.LabelLocation;
                else
                    try
                        pt.UpgradeOpen();
                        tv = (TypedValue)arInputArgs.GetValue(1);
                        var ptlocation = (Point3d)tv.Value;
                        pt.ResetLabelLocation();
                        pt.LabelLocation = ptlocation;
                        pt.DowngradeOpen();
                        retval = true;
                    catch
                        retval = false;
                tr.Commit();
                db.TransactionManager.QueueForGraphicsFlush();
            return retval;
tcorey
in reply to: Jeff_M
Hi @Jeff_M Thanks to your dll, I was able to create a lisp that exports points to a text file. There is a column that tells if the point label has been dragged and, if it has, then columns for label location x, y, and z. Now I intend to write a lisp that imports the points and applies the dragged location. Fun stuff!
Tim Corey
Redding, CA
tcorey
in reply to: Jeff_M
Here is the LISP:
(defun c:DES_PtExpWithdragLoc ( / )
(vl-load-com)
(getdoc)
(vl-cmdf "netload" "C:\\Data\\_Autodesk Custom\\C3DLispTools.dll");load the dll that Jeff Mishler wrote. Thanks, Jeff!
(setq fl (open (strcat (filenamegetter) "_withDragStateLocation.txt") "w"))
(write-line "PtNumber, Easting, Northing, Elevation, Raw Description, IsDragged, Dragx, Draxy, Dragz" fl)
(setq pts (vlax-get c3ddoc 'Points)
	  cnt (vlax-get pts 'Count)
	  ctr 0)
	  (while (< ctr cnt)
		(setq pt (vlax-invoke pts 'Item ctr)
			  pte (vlax-vla-object->ename pt)
			  East (vlax-get pt 'Easting)
			  North (vlax-get pt 'Northing)
			  Elev (vlax-get pt 'Elevation)
			  RawDs (vlax-get pt 'RawDescription)
			  Num (vlax-get pt 'Number)
			  (if (islabeldragged pte)
					(progn
						(setq LblLoc (pointlabellocation pte)
							  lblX (car lblloc)
							  lblY (cadr lblloc)
							  lblZ (caddr lblloc)
					(setq Dragged 1)
					(setq Dragged 0)
					(if (= dragged 1)
						(write-line (strcat (rtos num 2 0) "," (rtos east 2 4) "," (rtos north 2 4) "," (rtos Elev 2 3) "," RawDs "," (itoa dragged) "," (rtos lblx 2 4) ","
											(rtos lbly 2 4) "," (rtos lblz 2 4))
									fl)
											(rtos Elev 2 3) "," RawDs "," (itoa dragged))
									fl)
			(setq ctr (1+ ctr))
			(close fl)
			(princ)
(defun filenamegetter ( / pref)
  (setq pref (getvar "DWGPREFIX")
	dwgnm (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4))
  (setq dwgnm (strcat pref dwgnm))
;thanks to Jeff Mishler for the following code.
(defun getAecAppNumber (/ );c3dnumber c3dproduct c3drelease)
  (setq	C3Dproduct (strcat "HKEY_LOCAL_MACHINE\\"
			   (if vlax-user-product-key
			     (vlax-user-product-key)
			     (vlax-product-key)
	C3Drelease (vl-registry-read C3Dproduct "Release")
	C3Dnumber  (substr
		     C3Drelease
		     1
		     (vl-string-search
		       C3Drelease
		       (+ (vl-string-search "." C3Drelease) 1)
(defun getdoc ( / )
  (setq appno (getaecappnumber))
  (setq	acadapp	(vlax-get-acad-object)
	c3dapp	(vla-getinterfaceobject acadapp (strcat "AeccXUiLand.AeccApplication." appno))
	C3Ddoc	(vla-get-activedocument C3Dapp)
)					;end function
Tim Corey
Redding, CA
Rail Community
