How to Extract Alignment Elevation using VBA?
alexisgacia
alexisgacia
Please help. I am new to Civil 3D.
I'm trying to extract the elevation of my alignment by selecting the location in the alignment and return the elevation and station number.
Please check the below code.
Private Sub CommandButton1_Click()
    GetBaseCivilObjects
    Dim oAlignment As AeccAlignment
    Dim oProfile As AeccProfile
    Dim oProfileVw As AeccProfileView
    'Dim oGeometryPoint As aeccGeometryPoint
    Dim mPnt As Variant
    Dim oEnt As AcadEntity
    Me.Hide
    ThisDrawing.Utility.GetEntity oEnt, mPnt, "Select Alignment Location:"
    ThisDrawing.ModelSpace.AddCircle mPnt, 1
    If (oEnt Is Nothing) Then GoTo xend
    Dim mStation As Double
    Dim mElevation As Double
    Dim sStation As String, sElevation As String
    If (TypeOf oEnt Is AeccAlignment) Then
        Set oAlignment = oEnt
        For Each oProfileVw In oAlignment.ProfileViews
            oProfileVw.FindStationAndElevationAtXY mPnt(0), mPnt(1), mStation, mElevation
            sStation = ThisDrawing.Utility.RealToString(mStation, acDecimal, 2)
            sElevation = ThisDrawing.Utility.RealToString(mElevation, acDecimal, 2)
            ThisDrawing.ModelSpace.AddMText mPnt, 10, "Elevation: " & sElevation & vbCrLf & _
                                                      "Station: " & sStation & vbCrLf & _
                                                      "oAlignment: " & oAlignment.Name & vbCrLf & _
                                                      "Displayname: " & oProfileVw.DisplayName & vbCrLf & _
                                                      "Profile Layer: " & oProfileVw.Layer & vbCrLf & _
                                                      "StationStart: " & oProfileVw.StationStart
        Next
xend:
    Me.show
End Sub
Thanks in advance.
Alex
Jeff_M
Unless your ProfileViews are on the alignment your code will fail. Selecting the Alignment and using the pickpoint you should get the station and offset of that point. Then get the elevation of a profile using that station with the ElevationAt method. Finally, you can get the XY location in the ProfileViews of that station and elevation with the FindXYAtStationAndElevation method.
Jeff_M, also a frequent Swamper
alexisgacia
Hi Jeff,
Thank you for the reply.
During selection of alignment, no value was extracted for the elevation.
Below the code that I use to select the alignment.
The only value that I get from mpnt is the XY only and Z is always 0.
I used the command FindStationAndElevationAtXY by feeding the XY as parameter to get the Station and Elevation but no success.
Is there any ways to extract the elevation?
Thanks and best regards,
Alex
Jeff_M
As I mentioned in my first reply, you need to get the Station & Offset using the picked point. Then you use the Station to find the Profile Elevation. Finally, if you need to locate the Station & Elevation in the profileViews you use the already obtained Station & Elevation to get the XY for those points.
Pseudo code...I don't use VBA so the syntax may be off, but this is the general idea:
oAlignment.StationOffset(x, y, station, offset)
prof = oAlignment.Profiles[ProfileName]
elev = prof.ElevationAt(station)
oAlignment.ProfileViews[0].FindXYAtStationAndElevation(station, elev, x, y)
alexisgacia
Wow! It works well. Thank you very much.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
