how to connect or disconnect fitting from pressure pipe using c#
any one can tell me how can i connect or disconnect fittings from selected pressure pipe using c# code
stevenh0616
I've been trying to do a lot of things with the Pressure Pipe API, but it doesn't work. I've been told for a few years now that Pressure Pipes are an emerging component of Civil 3D... and the Pressure Pipe .NET API hasn't been updated since it was first rolled out. Thus, I don't believe this is possible with the current API.
Perhaps others have better input than I do, but that's been from my efforts in trying to get it to work.
Steve Hill, Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
soonhui
@Anonymous ,
I've filed a case for pressure pipe support at ideas forum, please consider to go there and give it a vote if you want it to be done quickly
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
