Is there a way to preview a TextStyle in Civil 3D using C#.net?
Any insights or suggestions would be greatly appreciated. Thank you!
You can use the DrawString method of the System.Drawing.Graphics to draw onto a bitmap image from a given string, font, brush, and point.
Here is a snippet of code from my repos with some unnecessary lines removed.
Using bmp As New Bitmap(200, 40)
Using g As Drawing.Graphics = System.Drawing.Graphics.FromImage(bmp)
Dim size As SizeF = g.MeasureString(msg, font)
g.Clear(Color.Magenta) 'Used to Create Transparency
g.FillRectangle(brushWhite, 0, 0, size.Width + 6, size.Height + 4)
g.DrawRectangle(blackPen, 1, 1, size.Width + 2, size.Height + 2)
g.DrawString(msg, font, brushBlack, New PointF(2, 2))
End Using
End Using
I'm looking for a method to preview different text styles. Instead of generating an image with specific text content, I want to explore and visualize various text styles.
I am confused. What you have circled is an image displayed in a dialog box of the selected text style. The code that I posted could generate that image. So, with that said, I guess I am not sure what you mean when you say you want to explore and Visualize various text styles. So, what do you mean when you want to preview the text style?
The sample code does not generate the same preview image as displayed in the TextStyle window.
Refer attached image for reference.
However, I was able to replicate the correct preview image by following these steps:
While this approach works, I am seeking an alternative method that:
Could you suggest any such alternatives or optimizations?
