Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
How do I programmatically turn on/off corridor baselines in C3D?
5 REPLIES 5
heyimsp12
346 Views, 5 Replies
In C3D under Corridor properties > Parameters we have an option to show/hide all the baselines of a corridor as shown in the figure below. I want to do something similar using C3D API, is there a way to do this using C# or VBA?
Or is there any alternate way to show/hide corridors?
Labels (5)
5 REPLIES 5
hosneyalaa
in reply to: heyimsp12
Hi
as an idea Maybe you need classesCheckBox in your code
heyimsp12
in reply to: hosneyalaa
@hosneyalaa No no.
I meant to ask if there is any property of Corridor or baseline in civil 3d API that can allow me to turn it on/off?
hosneyalaa
@heyimsp12
I understand what you want
I don't know if in civil 3d API This option
You can search at
Autodesk. Civil. Settings Namespace
https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=b7139987-5e0a-7d2d-85f1-1cf623575d72
gleeuwdrent
The property 'NeedsProcessing' defines if a baseline or baseline region is turned of (false) or on (true).
heyimsp12
in reply to: gleeuwdrent
Thank you @gleeuwdrent that worked.
Along with 'NeedsProcessing' property of baselines, I also found corridor has 'Visible' property which i was able to use together to get the required results. In order to completely hide the corridor from Model space, both property (in corridors as well as baseline) has to be used.
Rail Community
