how can i get and set property set data(extended data) in civil 3d using c#
Message 1 of 12
 how can i get and set property set data(extended data) in civil 3d using c#  on each entity using c#
Replies (11)
Message 2 of 12
Have same issue...
Message 3 of 12
dunc.sargent
So in my situation I extra object information in three places:  Object Data, XData, and Extension Dictionaries.
The Property Sets are down in an Extension Dictionary.
DBObject dbObject = pcc.TheTransaction.GetObject( dbId, OpenMode.ForRead );
ObjectId dbIdExtDict = dbObject.ExtensionDictionary;
if( !dbIdExtDict.IsValid )
    Acad.Report( "Object has no extension dictionary." );
    break;
DBDictionary dbExtDict = pcc.TheTransaction.GetObject( dbIdExtDict, OpenMode.ForRead ) as DBDictionary;
if( dbExtDict == null )
    break;
Acad.Report( "Extension dictionary:" );
ReportDictionary( pcc, dbExtDict, 0 );
Acad.Report( "\n" );
pcc.TheTransaction is just a drawing transaction.  Acad.Report just burps some output to the command window.
Down inside ReportDictionary I go through the dictionaries looking for the PropertySet one.
public static void ReportDictionary( CaddDB.Context.PublisherCommand pcc, DBDictionary dbDictionary, int level )
    do
        try
            string indent = "    ";
            for( int i = 0; i < level; i++ )
                indent += "    ";
            int n = 0;
            foreach( DBDictionaryEntry ent in dbDictionary )
                DBObject dbEntry = pcc.TheTransaction.GetObject( ent.Value, OpenMode.ForRead, false );
                if( dbEntry == null )
                    continue;
                string type = String.Format( "({0}): ", dbEntry.GetType().ToString() );
                Acad.Report( String.Format(
                    "{0}{1}.{2}: key: {3}; type: {4}",
                    indent,
                    level,
                    n++,
                    ent.Key,
                    type
                if( dbEntry.GetType() == typeof( Xrecord ) )
                    Xrecord xRec = dbEntry as Xrecord;
                    if( xRec == null )
                        continue;
                    ReportRecord( pcc, xRec, level + 1 );
                    continue;
                if( dbEntry.GetType() == typeof( DBDictionary ) )
                    DBDictionary dbd = dbEntry as DBDictionary;
                    if( dbd == null )
                        continue;
                    ReportDictionary( pcc, dbd, level + 1 );
                    continue;
                if( dbEntry.GetType() == typeof( PropertySet ) )
                    PropertySet ps = dbEntry as PropertySet;
                    if( ps == null )
                        continue;
                    ReportPropertySet( pcc, ps, level + 1 );
                    continue;
        catch( System.Exception ex )
            Chronicle.AddException( ex );
    while( false );
public static void ReportPropertySet( CaddDB.Context.PublisherCommand pcc, PropertySet ps, int level )
    do
        try
                indent += "    ";
            ObjectId idDef = ps.PropertySetDefinition;
            // pcc.TheTransaction is a drawing transaction
            PropertySetDefinition propSetDef = (PropertySetDefinition)pcc.TheTransaction.GetObject( idDef, OpenMode.ForRead );
            PropertyDefinitionCollection propDefCol = propSetDef.Definitions;
            // create a list so that it's easier to index later
            PropertyDefinitionList propDefList = new PropertyDefinitionList();
            foreach( PropertyDefinition propDef in propDefCol )
                propDefList.Add( propDef );
            PropertySetDataCollection psdc = ps.PropertySetData;
            foreach( PropertySetData psd in psdc )
                PropertyDefinition[] ies = propDefList.Where( x => x.Id == psd.Id ).ToArray();
                if( ies.Count() > 0 )
                    PropertyDefinition propDef = ies[0];
                    Acad.Report(
                            $"{indent}{psd.Id}, {psd.DataType}, {propDef.Name} = {psd.GetData()}"
                else
                    Acad.Report(
                            $"{indent}{psd.Id}, {psd.DataType}, {psd.FieldBucketId} = {psd.GetData()}"
    while( false );
So in my example you get the value at psd.GetData(), and you could use SetData() as you like.
I hope that helps.
--dunc
Message 4 of 12
norman.yuan
Great code, @dunc.sargent
Since your code actually uses class "PropertySet", I assume that the DLL project has AecPropDataMgd.dll set as reference. If so, why bother to check ExtensionDictionary to determine if PropertySet data existence, and if yes, cast the Dictionary entry as PropertySet object?
These 2 methods:
PropertyDataServices.GetPropertytSetDefinitionUsed(DBObject ent)
PropertyDataServices.GetPropertySet(DBObject ent, ObjectId setdefId)
would let us find all PropertySets attached to an Entity without the need to dig into the ExtensionDictionary first.
Norman Yuan
Drive CAD With Code
Message 5 of 12
dunc.sargent
I was exploring through extension dictionaries in general before I added the PropertySet stuff.  When I do a specific PropertySet task, I'll certainly use the PropertyDataServices.  Those are good tips, thanks for that!
--dunc
Message 6 of 12
lu_an_jie
https://github.com/AndreasLuka/ALC-C3D-LX/tree/master/ALC-SolidStair
Is a complete plug-in using property sets to create a solid stair
It includes functions for
  • during start-up sanity check if property set definition exist and if not create a property set definition
  • write, read and update  property sets attached to object
  • create object based on property set data
Regards
Andreas Luka (Lu An Jie)
http://www.luka-consult.de
Creator of the LX-Stair App for Civil 3D
Message 7 of 12
moonlikestoneBX57A
Thanks for your nice code, @dunc.sargent
After I try to use setData() to add new property in the property set, I got some question:
I can get the new property information in the runtime of program.
After the program was finished, the new property will not be found in the object information.
Do I need to update the property definition of the object?
Or the property set need to be added by other method?
Message 8 of 12
lu_an_jie
Could pleas p;ost your code, so i can have a look to it.
Regards
Message 9 of 12
moonlikestoneBX57A
Hi, @lu_an_jie:
This is my code to add new property into the property set:
Using:
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using civilAppSer = Autodesk.Civil.ApplicationServices;
using civilApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.Aec.PropertyData.DatabaseServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.Civil.DatabaseServices;
Code:
using(Transaction ts = civilApp.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
ObjectIdCollection id = doc.GetPipeNetworkIds(); if (id == null) civilApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("No Pipe network."); else { Network network = ts.GetObject(id[0], OpenMode.ForWrite) as Network; Pipe pipe = ts.GetObject(network.GetPipeIds()[0], OpenMode.ForWrite) as Pipe; ObjectIdCollection psdColl = PropertyDataServices.GetPropertySets(pipe); if (psdColl == null) { MessageBox.Show("Object has not Property Set"); return; } MessageBox.Show("This object has" + psdColl.Count + "Property Set"); PropertySet set = psdColl[0].GetObject(OpenMode.ForWrite, false) as PropertySet; ObjectId idDef = set.PropertySetDefinition; PropertySetDefinition def = (PropertySetDefinition)ts.GetObject(idDef, OpenMode.ForWrite); MessageBox.Show(def.Name); PropertyDefinitionCollection propDefColl = def.Definitions; PropertyDefinition Newdef = new PropertyDefinition(); Newdef.DataType = Autodesk.Aec.PropertyData.DataType.Text; //類型 Newdef.Name = "NewAutoTestProperty"; Newdef.Description = Newdef.Name; Newdef.IsVisible = true; def.Definitions.Add(Newdef); foreach (PropertyDefinition propDef in propDefColl) { if (propDef != null) MessageBox.Show(propDef.Name); } }
Thanks for your help!
Message 10 of 12
lu_an_jie
Your transaction is incomplete., ts.Commit()  is missing.
I also would recommend some more changes to make your routine safer. and easier to read.
First easier read:
set variable for document, database  and editor
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
TransactionManager tm = db.TransactionManager;
Editor ed = doc.Editor;
Second usability:
Use MessageBox or Editor for Error messages.
Second safety, logic performance :
if (id == null)
{ doc.Editor.WriteMessage("No Pipe network.");
return;
//no need for else as you already leave the function in case of no network
using(Transaction ts = doc.Database.TransactionManager.StartTransaction())
try
// network and pipe need only read rights
Network network = ts.GetObject(id[0], OpenMode.ForRead) as Network;
Pipe pipe = ts.GetObject(network.GetPipeIds()[0], OpenMode.ForRead) as Pipe;
// your code here
// commit your changes
ts.Commit ();
catch (Exception ex)
doc.Editor.WriteMessage(ex.Message);
No need to open a transaction if you do not have a pipe network
Network and pipes you put only ForRead
Use try and catch  for write operation, so you can see what's may going wrong
Write your data in to the drawing by committing the transaction
Regards
Message 11 of 12
Is there any way to do this with using the PropertySet class and referencing the AecPropDataMgd.dll? Due to design automation restrictions: https://stackoverflow.com/questions/57853402/aec-assemblies-in-forge-design-automation/
Message 12 of 12
norman.yuan
Forge design automation's support for AutoCAD verticals has always been a gray area (or a work in progress, to put it in better words) as to whether full vertical-specific APIs/features are available or not. I think you'd better directly ask Autodesk's Forge support team for a clear answer.
Norman Yuan
Drive CAD With Code
