Help with my Lisp to insert Dynamic block in a certain visual state.
AtchleyC
AtchleyC
In this lisp there are 2 blocks with vis states. I have listed them and can select them at command prompt. However when I place them they alway show the same vis state for each selection. Block Fit-Bend has 4 vis states and always displays the 90 DEG vis state. Block Fit-TEE-X ha two vis states and always show the TEE vis state. How can I make them show the selected vis state?
Jeff_M
Please provide a dwg with those 2 blocks defined.
AtchleyC
Hey Jeff, Thanks for taking a look at it.
Here is the Dwg.
