Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Help Setting LinetypeScale to Feature Line via Lisp
6 REPLIES 6
CodeDing
298 Views, 6 Replies
Hello all,
It seems that I cannot properly set the LinetypeScale of a Feature Line (the one that shows up in the Properties palette, NOT the feature line Style) via Lisp. I'll post some screenshots and code below, but it appears that SOMEHOW whenever I use a code to SET the LinetypeScale property, it ROUNDS my number before applying it to the entity. [ex. 1.2-> 1.0, 1.7->2.0, 0.2->0.0, 0.7->1.0].
Any help on this? I can't find it being mentioned before. I would really like to be able to keep this in Lisp, but any thoughts or input on the matter is appreciated. I have also attached the dwg (2018 version) for your testing.
Best,
~DD
[P.S. I have also tried (entmod ...) to no avail]
Original Feature Line, before code edits:
Original Feature LineOriginal Feature Line
Now, when I apply EITHER of the two following codes...
(vlax-put-property
  (vlax-ename->vla-object (car (entsel "Select Feature Line")))
  'LinetypeScale
  0.2
(vla-put-LinetypeScale
  0.2
...I receive the Property on the Left image. Whereas when I MANUALLY change it, I get the Property on the Right image:
Left: After applying code / Right: After applying manuallyLeft: After applying code / Right: After applying manually
Likewise, when I apply either of these two codes...
(vlax-put-property
  'LinetypeScale
  1.7
  1.7
...I receive the following (Left is after code input, Right is after Manual input):
~DD
Senior CAD Tech & AI Specialist
Need AutoLisp help? Try my custom GPT 'AutoLISP Ace':
https://chat.openai.com/g/g-Zt0xFNpOH-autolisp-ace
6 REPLIES 6
hosneyalaa
in reply to: CodeDing
hi
try
Can you change LinetypeScale from the style Feature Line
CodeDing
in reply to: hosneyalaa
@hosneyalaa ,
Yes, I can, but that is not the issue my post is trying to resolve.
Best,
~DD
~DD
hosneyalaa
TRY
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/changing-linetype-scales/td-p/8179790
(defun c:ltschange ( / doc scl )
    (initget 6)
    (if (setq scl (getreal "\nSpecify new linetype scale: "))
        (vlax-for blk (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
            (if (= :vlax-false (vla-get-isxref blk))
                (vlax-for obj blk
                    (if (and (vlax-write-enabled-p obj) (vlax-property-available-p obj 'linetypescale t))
                        (vla-put-linetypescale obj scl)
    (vla-regen doc acallviewports)
    (princ)
CodeDing
@hosneyalaa ,
I receive the same result as if running my original code. See image below.
Best,
~DD
~DD
hippe013
As to why it is rounding the lintypescale, I have no idea, it's anybody's guess, and may even be a bug. Though, why are you trying to set the linetype scale directly on the entity when it appears that it has no effect on the display of the linetype? As it was pointed out, it is controlled by the featureline style. Now, as far as your drawing goes, and everybody does things differently, but the first thing that I checked was the values of LTSCALE, PSLTSCALE, and MSLTSCALE.
CodeDing
in reply to: hippe013
@hippe013 ,
Yeah, at this point, I'm just probably going to chalk it up as a lost cause.
If a Feature Line is ever exploded to a 3D Polyline, the LT Scale transfers with it, so I am trying to account for that possibility... Now, I do understand that the workflow of a user to change LTScale of a Feature Line then explode to a 3D Polyline would be miniscule AT BEST, but I was still trying to account for it, nonetheless. I've seen crazier workflows...
Yeah, one of my templates has an LTSCALE that is set to 25.4 to account for some Imperial/Metric Linetype conversions.
If I find anything in the meantime, I'll come back to mention it, but there does not seem to be a direct solution to my original question at this time. Anyway, thank you guys for looking into this.
Best,
~DD
~DD
Rail Community
