Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
GetIUnknownFromObjectId crash
0 REPLIES 0
Message 1 of 1
qa1kallocstudios
78 Views, 0 Replies
If someone can help us with the proper use of ObjectPropertyManagerPropertyUtility.GetIUnknownFromObjectId inside Civil3D plugin since we are getting a random crash on exit. We can reduce that randomness by and have it crash more consistently when we call the below function in a loop 50 times.
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcadEntity = Autodesk.AutoCAD.DatabaseServices.Entity;
AcDb.DBObject dbObj = trans.GetObject(m_ObjectId, AcDb.OpenMode.ForRead, true);
AcadEntity entity = dbObj as AcadEntity;
 public static bool GetOPMProperties(AcDb.Entity entity, Transaction trans )
    IntPtr pUnk = ObjectPropertyManagerPropertyUtility.GetIUnknownFromObjectId(entity.Id);
    if (pUnk != IntPtr.Zero)
        // The below call would cause a crash due to System.AccessViolationException: Attempted to read or write protected memory.
        using (CollectionVector properties = ObjectPropertyManagerProperties.GetProperties(entity.Id, false, false))
        int count = Marshal.Release(pUnk);
        // In a loop that call this function 50 times
        /* 29172 is the entity's Id Handle Value. count is the count got back from Marshal.Release(...)
        29172 count=0
        29172 count=0
        29172 count=-1073741823
        29172 count=0
        29172 count=0
        29172 count=0
        29172 count=0
        29143 count=0
        29143 count=0
        29143 count=-1073741823
        29113 count=0
        29113 count=0
        29113 count=0
        29113 count=0
        29113 count=0
        29113 count=0
        29113 count=0
        29113 count=0
        Exception thrown: 'System.AccessViolationException' in acmgd.dll
        An unhandled exception of type 'System.AccessViolationException' occurred in acmgd.dll
        Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Now if we changed to the below call that is asked to pass-in an object we don't get crash, but we don't get a lot of properties since GetIUnknownFromObject would return null when
ObjectPropertyManagerPropertyUtility.ObjectSupportsNonDBResidency(entity) return false
public static bool GetOPMProperties_NonCrashing(AcDb.Entity entity, Transaction trans )
    IntPtr pUnk = ObjectPropertyManagerPropertyUtility.GetIUnknownFromObject(entity, false);
        using (CollectionVector properties = ObjectPropertyManagerProperties.GetProperties(entity, false, false))
So what does ObjectPropertyManagerPropertyUtility.ObjectSupportsNonDBResidency(entity) mean, and how can I get it such that GetIUnknowFromObject would non-null pUnk?
Thanks for the help!
Tags (1)
Labels (1)
  • API
0 REPLIES 0
Rail Community
