Ideally I'd want to make a selection of cogo points and export them as a *.csv with the following columns:
- Northing
- Easting
- Elevation
- (RAW) Description
- Rotation (as seen in Properties of the Cogo Point, "Marker Rotation" under "Annotation")
- Layer (layer where Cogo point sits on)
Is this possible?
I've tried DATAEXTRACTION, MAPEXPORT and EXPORTPOINTS for this one, but it seems like I'm looking a little more functionality.
Context: Coming from a web-development background, I've been given a fairly complex landfill infrastructure drawing to make a GIS application where on-site people can quickly find a location by it's name on a map. (Basically google maps with search functionality) on their tablets/phones. This would help streamline the process as the infrastructure drawing updates periodically.
Solved by hippe013. Go to Solution.
Here is a quick example on how to do this using lisp.
(defun c:cogoExport ( / ss fileName f n)
(setq ss (ssget '(( 0 . "AECC_COGO_POINT"))))
(setq fileName (getfiled "Export to" "" "csv" 1))
(if (and ss fileName)
(progn
(setq f (open fileName "w"))
(setq n 0)
(repeat (sslength ss)
(setq cogo (vlax-ename->vla-object (ssname ss n)))
(setq line (cogo:pntToString cogo))
(write-line line f)
(setq n (+ n 1))
(close f)
(princ (strcat "\nPoints have been exported. Quantity: " (itoa n)))
(princ "\nCommand Canceled.")
(princ)
(defun cogo:pntToString (cogo / northing easting elev rawDesc layer lblRot)
(setq northing (rtos (vlax-get-property cogo 'Northing) 2 3))
(setq easting (rtos (vlax-get-property cogo 'Easting) 2 3))
(setq elev (rtos (vlax-get-property cogo 'Elevation) 2 3))
(setq rawDesc (vlax-get-property cogo 'RawDescription))
(setq layer (vlax-get-property cogo 'Layer))
(setq lblRot (rtos (vlax-get-property cogo 'LabelRotation) 2 8))
(strcat northing "," easting "," elev "," rawDesc "," lblRot "," layer)
This is incredible! I did a quick test to it and it was like magic!
I did need marker rotation thought, and with a little research and was able to get it!
I replaced your line:
with:
(setq rot (rtos (* (/ (vlax-get-property cogo 'Rotation) pi) 180) 2 0))
to get the marker rotation in degrees (which is what I need).
I made sure to replace lblRot with rot in the variable names on 'defun' line 22 too. 🙂
Thank you for the help hippe013 !
Dropping these here with my most recent implementation in case someone else might find it useful in the future/I forget and will have to return here 🙂
Basically exports csv of selection with the following columns:
(defun getaeccApp (module / *acad* C3D) ;; module must be "Land", "Pipe", "Roadway", or "Survey"
(vl-load-com)
(if (and (setq *acad* (vlax-get-acad-object))
(setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
(if vlax-user-product-key
(vlax-user-product-key)
(vlax-product-key)
C3D (vl-registry-read C3D "Release")
C3D (substr
C3D
1
(vl-string-search
C3D
(+ (vl-string-search "." C3D) 1)
C3D (vla-getinterfaceobject
(strcat "AeccXUi" module ".Aecc" (if (= (strcase module) "LAND") "" module) "Application." C3D)
C3D
(defun c:cogoExport ( / ss fileName f n pgs)
(setq c3ddoc (vlax-get (getaeccapp "Land") 'activedocument))
(setq defaultFileName (strcat
(vl-string-subst "\\Downloads\\" "\\Documents" (getvar 'MYDOCUMENTSPREFIX))
(vl-string-subst "" ".dwg" (getvar "dwgname"))
".csv"
(setq fileName (getfiled "Export to" defaultFileName "csv" 1))
(progn
(setq n 0)
(write-line "Point number,Northing,Easting,Elevation,Raw Description,Name,Rotation,Layer,PrimaryPointGroupName" f)
(setq line (cogo:pntToString cogo c3ddoc))
(write-line line f)
(setq n (+ n 1))
(close f)
(princ)
(defun cogo:getPointPrimaryPointGroup (pt c3ddoc / IDX PTGRP)
(setq idx -1)
(vlax-for grp (vlax-get-property c3ddoc 'pointgroups)
(if (and (= (vlax-invoke-method grp 'containspoint (vlax-get-property pt 'number)) :vlax-true)
(> (vlax-get-property grp 'DrawPriority) idx)
(progn
(setq idx (vlax-get-property grp 'DrawPriority))
(setq ptgrp grp)
ptgrp
(defun cogo:pntToString (cogo c3ddoc / northing easting elev rawDesc layer rot ptNum ptName primaryPointGroupName)
(setq ptNum (vlax-get-property cogo 'Number))
(setq ptName (vlax-get-property cogo 'Name))
(setq primaryPointGroupName (vlax-get-property (cogo:getPointPrimaryPointGroup cogo c3ddoc) 'Name))
(strcat (itoa ptNum) "," northing "," easting "," elev "," rawDesc "," ptName "," rot "," layer "," primaryPointGroupName)
