Delete all elevation points on all/multiple selected featurlines
kylehalchin
kylehalchin
1. What I would like to do is be able to select a bunch of featurelines that all have a lot of elevation points and then delete all elev points at once instead of going thru each line individually. Does anyone know of a lisp out there that will delete all elevation points (not PI points) of multiple/all featurelines or 3D polyines? Or a better workflow?
2. And on the flip side...does anyone know of a lisp that would add elevation points to a bunch of featurelines at a given interval all at once (instead of one individual line at a time)?
Any input is welcome.
dlanorh
A drawing containing an example elevation point and feature line might help, for me AutoCAD2010 format.
I am not one of the robots you're looking for
braudpat
Hello
Have you :
- 3D single Lines?
And/Or
- 2D PLines at multiple Elevations ?
And/Or
- 3D PLines ?
The first 2 cases can be moved to Elevation = Zero with Properties dialog box...
For 3D Plines you need a Lisp ...
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Jeff_M
This takes care of the first request:
(defun c:removeallelevationpoints (/ ss idx ent fl elevpts pt i)
  (vl-load-com)
  (if (setq ss (ssget '((0 . "AECC_FEATURE_LINE"))))
    (progn
      (setq idx -1)
      (while (setq ent (ssname ss (setq idx (1+ idx))))
	(setq fl (vlax-ename->vla-object ent))
	(setq elevpts (vlax-invoke fl 'getpoints 2))
	(setq i -1)
	(while (< i (- (length elevpts) 1))
	  (setq pt (list (nth (+ 1 i) elevpts) (nth (+ 2 i) elevpts) (nth (setq i (+ 3 i)) elevpts)))
	  (vlax-invoke fl 'DeleteFeaturePoint pt)
  (princ)
Jeff_M, also a frequent Swamper
kylehalchin
I'm working with 3d plines and featurelines.
kylehalchin
Thanks Jeff_M! I'll try that string of code first thing monday!
