Custom subassembly between corridor sections display issue
idoQEYMP
idoQEYMP
I wrote a .net custom subassembly of a concrete ditch (see it in the picture on the left side).
I can see the ditch fine at sections that match the corridor assembly insertion stations, but can't see the ditch part in between assembly insertions. I do see other parts of the subassembly like the ground replacement under the ditch, which is created AFTER the ditch shape and links in the same function.
Every other subassembly that I've created works fine in between sections and I can't find the reason for this behavior.
This happens between all the stations not just the case shown in the picture.
Any idea why this can happen?
idoQEYMP
code for the function that creates the ditch:
**edit: It was caused by a link with length of 0. 😖
