(defun c:test_pp ( / ) ;algn srf ststa endsta csta incr off x y xy pt
(vl-load-com)
(IF (OR
(setq algn (vlax-ename->vla-object (setq obent(car (entsel "\nSelect Polyline: ")))))
(while (not (= (vlax-get-property algn 'ObjectName) "AcDbPolyline"))
(setq algn (vlax-ename->vla-object (car (entsel "\nSelect Polyline: "))))
(PROGN
;; Jeff Mishler
(setq *acad* (vlax-get-acad-object))
(setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
(if vlax-user-product-key
(vlax-user-product-key)
(vlax-product-key)
C3D (vl-registry-read C3D "Release")
C3D (substr
C3D
1
(vl-string-search "." C3D (+ (vl-string-search "." C3D) 1))
C3D (vla-getinterfaceobject
*acad*
(strcat "AeccXUiLand.AeccApplication." C3D)
(setq C3Ddoc (vla-get-activedocument C3D))
(setq pnts (vlax-get C3Ddoc 'points))
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq blksObj (vla-get-blocks doc))
(vla-endundomark doc)
(vla-startundomark doc)
(setq spc (vla-get-modelspace doc))
(setq srf (vlax-ename->vla-object (setq ent (car (entsel "\nSelect Surface: ")))))
(while (not (= (vlax-get-property srf 'ObjectName) "AeccDbSurfaceTin"))
(setq srf (vlax-ename->vla-object (car (entsel "\nEntity must be C3D Surface. Try again: "))))
(sssetfirst nil (ssadd ent))
(Command "_AeccAddContourLabeling" "o" "no" obent "")
(setq entlbb (entlast))
(command "explode" entlbb)
(setq entlbbx (entlast))
(setq obj (vlax-ename->vla-object entlbbx))
(setq ename (GetLevel (vla-get-name obj) blksObj))
(mapcar 'cadr ename)
(mapcar 'car ename)
(setq enameXYZ (mapcar '(lambda(x Y)(LIST (CAR X) (CADR X) Y)) (mapcar 'cadr ename)(mapcar 'car ename) ))
(setq idx -1)
(while (setq ename (nth (setq idx (1+ idx)) enameXYZ ))
(setq oCogo(vlax-invoke pnts 'add ename))
(setq pntnums (vlax-get oCogo 'number))
(vla-put-NAME oCogo (strcat "EXPLODE CIVIL POINT & " (itoa pntnums)));NAME NETWORK;NAME NETWORK
(vla-put-description oCogo "CONVERT"); NAME MANHOLE
(vlax-put-property oCogo 'Style (strcat "Benchmark"))
(vlax-put-property oCogo 'LabelStyle "Elevation Only")
);;;(while
(princ)
;;https://www.cadtutor.net/forum/topic/70589-if-possible-help-with-a-small-change/?tab=comments#comment-566525
;; Roy_043
(defun GetLevel (nme blksObj / out)
(vlax-for obj (vla-item blksObj nme)
(cond
;;; (out)
;;; ((/= "V-NODE-TEXT" (strcase (vla-get-layer obj)))
;;; nil
((= "AcDbBlockReference" (vla-get-objectname obj))
(setq out (GetLevel (vla-get-name obj) blksObj))
((not (vlax-property-available-p obj 'textstring))
nil
((wcmatch (vla-get-textstring obj) "*#.#*")
(setq out (cons (list (last (LM:parsenumbers (vla-get-textstring obj)))(vlax-get obj 'insertionpoint)) out))
;; Parse Numbers - Lee Mac
;; Parses a list of numerical values from a supplied string.
(defun LM:parsenumbers ( str )
( (lambda ( l )
(read
(strcat "("
(vl-list->string
(mapcar
'(lambda ( a b c )
(if (or (< 47 b 58)
(and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
(and (= 46 b) (< 47 a 58) (< 47 c 58))
b 32
(cons nil l) l (append (cdr l) '(()))
(vl-string->list str)
