- Mute
- Permalink
- Report
Hello everyone. I need your help!
Is it possible to program a new type of surface analysis (in addition to the standard one from the options list) that will read data from a specific list of points (where x and y coordinates, z is the heat in a given coordinate) and build a heat map based on them? The result should be a 3D temperature map with the "Faces3d" type and heat analysis as in the screenshot (only the screenshot shows the height analysis).
Thanks in advance)
