create section view
create section view
anhtrung
Message 1 of 10
create section view
anhtrung
Hi everybody. I'm creating section view with .NET but i don't find Style and Band Set to add sectionview. Can every body help me do it? Thanks.
Replies (9)
Message 2 of 10
Jeff_M
I believe that the Create method uses the Styles set in the CreateSectionview settings. SO either change those to what you want to use before creating the SectionView, or set the styles for the SV after you create it.
Jeff_M, also a frequent Swamper
Message 3 of 10
flycoflyco
ObjectId svid = SectionView.Create("SectionView" + indexNum.ToString(), index, new Point3d(insertPosition.X + (indexXnum * 500), insertPosition.Y - (indexNum * 200), 0));
scv = ts.GetObject(svid, OpenMode.ForWrite) as SectionView;
SectionViewBandSet SctVwBndSet = scv.Bands;
Message 4 of 10
anhtrung
Hi flycoflyco. I have a create Sectionview but i can't set style for sectionview it. Have you method do it?
Message 5 of 10
Jeff_M
@anhtrung are you saying that
scv.StyleId = SectionViewStyleToUse.ObjectId;
or
scv.StyleName = SectionViewStyleToUse.Name;
don't work for you?
Message 6 of 10
anhtrung
@Jeff_M I have add Style into Sectionview but that make erro. I don't know how it?
Message 7 of 10
anhtrung
I have create SectionView from to code below:
ObjectId _o = SectionView.Create(l.ToString(), _id, _3d);
SectionView sect = tr.GetObject(_o, OpenMode.ForWrite) as SectionView;
ObjectId _band = _doc.Styles.SectionViewBandSetStyles[_Band];
sect.Bands.ImportBandSetStyle(_band);
SectionViewBandSet _set = sect.Bands;
But when i select Change Band Set so appear message box must to choose Band Set and then i have choose style Band Set style but program automatic close. I don't know make it how to do that, so can eyverybody help me, Please. I have send File below:
Message 8 of 10
Jeff_M
Please post your full code to test with, thanks!
Message 9 of 10
anhtrung
I send my code see below, can you help me. Thanks.
Message 10 of 10
Jeff_M
OK, yes, I get the same error after using your code. But then I restarted C3D and attempted to change the band set in an already existing sectionview group and received the same fatal error. So this appears to affect base C3D2016, SP2, (which is what I am testing in) and is not necessarily something wrong with your code.
