I'm trying to create Civil3d assembly with connected subassembly. I'm trying to access the Assembly group but no avail. Im using 2023 version of Civil3d.
Please check the below code that I created:
void _CreateAssembly_1()
var doc = Application.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var ed = doc.Editor;
CivilDocument civilDoc = CivilDocument.GetCivilDocument(doc.Database);
Point3d pntLoc = cSelection.Select_Point3d("Select Target Location");
if (pntLoc == new Point3d(0, 0, 0)) return;
using (doc.LockDocument())
using (Transaction tr = doc.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord ms = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
//acc3db.Assembly oAsm = new acc3db.Assembly();
ObjectId AssemblyId = civilDoc.AssemblyCollection.Add("test2", acc3db.AssemblyType.Other, pntLoc);
acc3db.Subassembly asm = AssemblyId.GetObject(OpenMode.ForWrite) as acc3db.Subassembly;
//civilDoc.SubassemblyCollection.Add("GEC_Carriageway_5layer",)
listBox1.Items.Clear();
// List Sub Assembly
foreach (var o in civilDoc.SubassemblyCollection)
acc3db.Subassembly subasm = o.GetObject(OpenMode.ForRead) as acc3db.Subassembly;
listBox1.Items.Add(" " + subasm.Name + " - " + subasm.Name);
// Create the CW subassembly
ObjectId subAsmId_R = civilDoc.SubassemblyCollection.ImportSubassembly("GEC_Carriageway_5layer_R_2", @"C:\ProgramData\Autodesk\C3D 2023\enu\Imported Tools\GEC_Carriageway_5_layer\af8a6c22d9e746f895aad89dcfcc3f42.atc", "43365f65-e04b-4df4-98ba-c308d3e806b4", pntLoc.Add(new Vector3d(0, 0, 0)));
ObjectId subAsmId_L = civilDoc.SubassemblyCollection.ImportSubassembly("GEC_Carriageway_5layer_L_2", @"C:\ProgramData\Autodesk\C3D 2023\enu\Imported Tools\GEC_Carriageway_5_layer\af8a6c22d9e746f895aad89dcfcc3f42.atc", "43365f65-e04b-4df4-98ba-c308d3e806b4", pntLoc.Add(new Vector3d(0, 0, 0)));
acc3db.Subassembly sub = (acc3db.Subassembly)subAsmId_R.GetObject(OpenMode.ForWrite);
acc3db.Subassembly sub_L = (acc3db.Subassembly)subAsmId_L.GetObject(OpenMode.ForWrite);
foreach (var o in sub_L.ParamsLong)
if (o.DisplayName.ToUpper() == "SIDE") o.Value = 1;
tr.Commit();
