Create Alignment Label for High and Low Point using c#
alexisgacia
alexisgacia
Good day.
I'm trying to create a tool that will make High and Low Point labels in the selected alignment if detected using single profile.
I was able to create this manually using the Alignment Label.
Below the sample code attempting to create it automatically.
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            var civdoc = CivilApplication.ActiveDocument;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                string mLabelStyleName = "High Point v1";
                LabelStyle mLabelStyle = null;
                foreach (var vf in civdoc.Styles.LabelStyles.AlignmentLabelStyles.VerticalGeometryPointLabelStyles)
                    var mStyle = tr.GetObject(vf, OpenMode.ForRead);
                    if(mStyle is LabelStyle)
                        mLabelStyle = (LabelStyle)mStyle;
                        if (mLabelStyle.Name == mLabelStyleName)
                            break;
                        else mLabelStyle = null;
                acc3db.Alignment align = (acc3db.Alignment)tr.GetObject(civdoc.GetAlignmentIds()[0], OpenMode.ForRead);
                var lblsetId = civdoc.Styles.LabelStyles.AlignmentLabelStyles.VerticalGeometryPointLabelStyles[mLabelStyleName];
// I stuck in this area and try to find it the internet but no samples provided.                Autodesk.Civil.DatabaseServices.AlignmentVerticalGeometryPointLabelGroup.Create(mLabelStyle.ObjectId, align.ObjectId, )
hosneyalaa
alexisgacia
Thank you for your reply.
What I'm trying to create is a tool to make it automatically generate Label for High Point and Low Point to all alignments using the first profile detected.
I can do it manually based on the link that you provided but only for 1 alignment. For multiple alignments, its not yet available.
