Convert circled survey figure to polyline or normall circle
lzedCB
Message 1 of 13
lzedCB
Hello folks, anyone has some LISP to convert Survey Figure with circular shape to normall circle, preserving its shape and placing the new circle at elevation "0"?
 Thanks!
Accepted solutions (3)
Replies (12)
Message 2 of 13
ВeekeeCZ
You should have posted a dwg.
Also, there is a dedicated C3D Customization forum over HERE .
(vl-load-com)
(defun c:SFCircle ( / s i p)
  (if (setq s (ssget))
    (repeat (setq i (sslength s))
      (setq p (vlax-invoke (vlax-ename->vla-object (ssname s (setq i (1- i)))) 'getpoints))
      (command "_.circle" "_3p"
	       "_non" (list (nth 0 p) (nth 1 p) 0.)
	       "_non" (list (nth 3 p) (nth 4 p) 0.)
	       "_non" (list (nth 6 p) (nth 7 p) 0.))))
  (princ)
Message 3 of 13
Kent1Cooper
If the "Survey Figure" is a Polyline, or perhaps can be Exploded into one, I have a routine to convert a circular Polyline into a Circle -- CirclePolylineSwap.lsp, >here<.  It has commands to go both ways -- use P2C for this.  If that otherwise does what you want, the elevation=0 part is easily added.
EDIT:  But I agree that a sample drawing would be useful.  We can't see your command line or properties in the video, so [for those of us who don't know what a "Survey Figure" is, at least] we don't know what you're working with.  And what is the significance of their becoming a not-quite-regular hexagon and pentagon, rather than a Circle as requested?
Kent Cooper, AIA
Message 4 of 13
komondormrex
hey there,
survey figure - what is it?
Message 5 of 13
lzedCB
@ВeekeeCZ Hello! Thanks for this one. Is it possible to add a step to delete the selected Circle Figures and to place the created circle in Survey's Figure layer instead putting it in layer "0"? Thanks a LOT.
Message 6 of 13
ВeekeeCZ
Use at your own risk. I know nothing about those objects, if there are some dependencies the plain removal might cause trouble.
(vl-load-com)
(defun c:SFCircle ( / s i p o)
      (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
      (setq p (vlax-invoke o 'getpoints))
      (setvar 'cmdecho 0)
      (setvar 'cmdecho 1)
      (vla-put-layer (vlax-ename->vla-object (entlast)) (vla-get-layer o))
      (vla-erase o)))
  (princ)
Message 7 of 13
lzedCB
Hello, thanks for your new code. It almost did it:
It's just converting one of those to circles and seems to be getting an "error" in the end! Thanks!
Message 8 of 13
ВeekeeCZ
Man, again, and for the very last time, post a drawing!
Message 9 of 13
lzedCB
Sorry for missing this message! Here it goes an example file.
Message 10 of 13
ВeekeeCZ
Ok, try this one.
(vl-load-com)
(defun c:SFCircle ( / s i p o e x p1 p2 p3)
  (setq x (ssadd))
  (if (setq s (ssget '((0 . "AECC_SVFIGURE"))))
      (setq e (ssname s (setq i (1- i))))
      (setq o (vlax-ename->vla-object e))
      (if (and (>= (length p) 9)
	       (setq p1 (list (nth 0 p) (nth 1 p) 0.))
	       (setq p2 (list (nth 3 p) (nth 4 p) 0.))
	       (setq p3 (list (nth 6 p) (nth 7 p) 0.))
	       (not (equal p1 p2 1e-6))
	       (not (equal p1 p3 1e-6))
	       (not (equal p2 p3 1e-6))
	(progn
	  (setvar 'cmdecho 0)
	  (command "_.circle" "_3p" "_non" p1 "_non" p2 "_non" p3)
	  (setvar 'cmdecho 1)
	  (vla-erase o))
	(ssadd e x))))
  (if (> (sslength x) 0)
    (progn
      (princ (strcat "\n" (itoa (sslength x)) " objects unprocessed."))
      (sssetfirst nil x)))
  (princ)
Message 11 of 13
lzedCB
I guess nothing happened with the new code:
Message 12 of 13
ВeekeeCZ
Try the update.
Message 13 of 13
lzedCB
Almost perfect @ВeekeeCZ . Seems that it only missed one conversion:
This is more than enough and I can fix it manually! Thanks a LOT.
