Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Constraint Rotation to Fixed Path
0 REPLIES 0
Message 1 of 1
PLM1987
233 Views, 0 Replies
hi everyone!
I am struggling to find a solution to something. I currently have a block and I would like to constrain it to a spline / poly / whatever (it's actually a surface profile but I'd trace it to use as a dummy object)
I want the object, when moved, to follow the line and rotate to maintain contact with the line at both rotation points.
I believe this image will help explain things more clearly.
EDIT: Aligning the block into position and using ARRAYPATH is currently the best solution
Labels (4)
0 REPLIES 0
Rail Community
