Civil 3D Copy Standard Pressure Network Gate Valve
hestingjj
hestingjj
I have a request that seems like it would be a simple thing to set up, but I cannot figure out how to do it. I would like to make a copy of the standard 200psi gate valve family that comes standard in the Civil 3D Push-On Catalog. I want to create a simple copy of these gate valves and save them as a separate family within the same catalog so that I can make a few customized edits. However, I cannot figure out how to copy them, or what DWGs they link to or really any information about how to do something like this. I do not want to create valves from scratch. I only want to copy these few valves. Is that something that is not possible or am I missing something here? See screenshot below.
AlmasSuljevic
Autodesk Support
Autodesk Support
I am trying to find some useful information from Development for you and answer why Copy option doesn't work. In the meantime please see following document (good stuff): PartPublishingWizardUsersGuide.docx found in here: C:\Program Files\Autodesk\AutoCAD 2020\C3D\Sample\Civil 3D API\Part Publishing Wizard
I hope it helps you.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
AlmasSuljevic
Autodesk Support
Autodesk Support
Please also see this document that will walk you through the process of creating new parts. https://www.autodesk.com/autodesk-university/class/Pressure-Content-Catalog-Editor-How-Create-Parts-...
Almas Suljevic
