Changing Line Label style formatting
Do any of you know how to edit the segment blocks in the line label style manager?
Currently, the General Segment Curve Chord Direction is set to put the spaces only between the numbers in a chord bearing (as shown in yellow below)
<[General Segment Curve Chord Direction(Udeg|FDMSdSp|MB|P4|RN|DSn|CU|AP|EN|DZN|OF)]>
Whereas the General Segment Direction puts the spaces between the quadrants and not the numbers (as shown in red below)
<[General Segment Direction(Udeg|FDMSd|MB|P4|RN|DSns|CU|AP|EN|DZN|OF)]>
The code for each appears identical, but they don’t work the same. I would like them to all be the same, not different, and I prefer the red over the yellow.
Replies (12)
hippe013
The format will control the degrees, minutes, and seconds and the direction will control the quadrants.
See Screen shot.
None of those options will change it the way I wanted, this puts a space between everything. The issue lies in the base command and this would force me to change each individually. I want a global change to the command
Thanks, tho.
In fiddling with the line direction styles, NONE OF THEM match the format of the chord bearing styles.
Why, Softdesk, Why?!
Crap, wrong screencap
hippe013
Try reading my post again. Format controls spaces between the digits. Direction controls spaces between the quadrants.
Jeff_M
What @hippe013 said. Here are 2 labels, a line segment and an arc with the chord bearing.
Also, note that you said the 2 format lines are the same, but look closer, they are not...
Jeff_M, also a frequent Swamper
hippe013
cwr-pae
What @hippe013  and @Jeff_M  said.
hippe013
@Anonymous Were you able to get your label settings to work the way you needed them to?
Yes, I'm working on that file again and got the proper configuration
Format: DD°MM'SS.SS"(spaced)
Direction: Short Name Spaced
Thanks again!
hippe013
Great! I'm glad that you were able to get it working.
andy.serrano
How do i remove the " 00" from this. so it can read S50 34'.40  ????
