Hello.
I'm trying to calculate the volume based on TinSurface's triangle.
But there are too many triangles, so I'm trying to reduce them.
Civil 3d has a basic simplification feature, but it changes the original triangles.
So, I am trying to extract the triangles with Polyline3d and merge them.
And I limited the area of the merged Polyline3d to not exceed a certain value.
However, it is unclear how to determine the criteria (or order) for merging, and overall, it seems to be a challenging task.
Could I get some advice on this?
Below is a picture of the work I am attempting.
ThankYou.
TinSurface got build using Delaunay triangulation, so it's built from triangles so deleting triangle edge will cause a gap in the surface, anyway if the intend is to calculate the volume why don't you just create TinVolumeSurface from two surfaces and get the volume?
@hellokim37YT92Y wrote:
That's correct. However, the TinSurface's triangulation is too fine and numerous, so I plan to merge them into appropriate sizes (based on area) and then create TinVolumeSurfaces for those sections to calculate the volume. Therefore, I am extracting the triangulation as Polyline3d to use as boundaries for the TinVolumeSurface.
In the merging process, I convert the two Polyline3d objects to Regions on a plane, merge them, and then convert the boundary of the Region back into Polyline3d. After that, I restore each point to the original Z-coordinates of the Polyline3d.
This process is quite challenging, so I wanted to ask if there might be a better approach.
still not clear to me, do you want to reduce the surface resolution so you would have less points? do you want instead of one volume (cut/fill) value you want time volumes for each tiny area (merged area) with horizontal level as average level?
It would be ideal to reduce the number of points in the TinSurface, but I understand that doing so would change the shape of the TinSurface. I want to avoid changing its shape because it might affect the volume. Therefore, I plan to extract the triangulation as Polylines and create TinVolumeSurfaces for each merged Polyline area. However, it is extremely challenging to come up with an algorithm for merging.
i agree it's not an easy task, try to learn about Voronoi diagram it is the step before Delauny triangulation and it gives bigger area, i think it's possible to get back to Voronoi from an existing Delauny .
good luck.
