calling autoCAD commands in VB.NET while CommandFlags.session is enabled
I am trying to call "-laydel" command from vb.net code. However I am getting error when using 'commandflags.session. How can I call an autocad command in vb.net while commandflags.session is enabled? I need to keep commandflags.session for my application. please see part of my code below:
<CommandMethod("cmdLaydel", CommandFlags.Modal + CommandFlags.Session)>
Public Sub deleteLayers2()
Dim layerTodel As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("USERS2")
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
ed.Command("-laydel", "n", layerTodel, "", "y", "")
End Sub
Civil3DReminders_com
I've never had luck sending stuff to the command line. It always seems to do it in the order I don't want.
I'd just delete the layer in .NET: http://forums.autodesk.com/t5/net/how-to-delete-layer-using-c-net/td-p/2409218/page/2
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Thanks for your reply Civil3DReminders.com. I am now deleting layer in .NET. However, my problem remains. I used to call commands, including those defined in lisp within a vb.net code I created for Civil 3d 2013. but now in civil 3d 2016, the same code can't work.
this is what used to work:
Dim app As AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
app.ActiveDocument.SendCommand("setq3" & vbCr)
Where setq3 is either an autoCad civil 3d command or a lisp command. I could even call a lisp function by enclosing it in blackets.
I know there has been changes since CAD 2015 (like removing fibers) but I am hopping I could still find a working way to send a command in autocad civil 3d 2016 while "commandFlags.session is enabled.
