i am experiencing an issue while getting the initial Min and Max elevation from a Newly create profile view: as the screenshot bellow the Min is 80 and the Max is 120
When Getting the Profile View Min and Max via code i initially get:
if i set the same elevation to 70 min and 130 max for example the profile view updates correctly and stets those Min and Max Correctly. Why is the initial ElevationMin & ElevationMax wrong when retrieving? but setting them works and also outputs correctly?
sample function:
public void SetProfileViewElevations()
//Documents
Document acadDoc = acadApp.DocumentManager.MdiActiveDocument;
Database db = acadDoc.Database;
Editor edt = acadDoc.Editor;
CivilDocument civilDoc = civilApp.ActiveDocument;
#region Variables
ObjectId profileviewID = ObjectId.Null;
double profileViewMinElevation;
double profileViewMaxElevation;
#endregion
Application.MainWindow.Focus();
//Selection
try
//Ask User to Seelct Profile VIew
PromptEntityOptions peo = new PromptEntityOptions("Select Profile View: ");
peo.SetRejectMessage("Selected item is not valid.");
peo.AllowNone = false;
peo.AddAllowedClass(typeof(ProfileView), true);
//Get Selected Results
PromptEntityResult per = edt.GetEntity(peo);
if (per.Status != PromptStatus.OK) return;
//Set profile view object id
profileviewID = per.ObjectId;
//Start Transaction
using (DocumentLock doclock = acadDoc.LockDocument())
using (Transaction trans = db.TransactionManager.StartTransaction())
//Create the Profile view object
ProfileView selectedprofileView = trans.GetObject(profileviewID, OpenMode.ForRead) as ProfileView;
if (selectedprofileView == null) return;
//Get the Current Values for Elevations
profileViewMinElevation = selectedprofileView.ElevationMin;
profileViewMaxElevation = selectedprofileView.ElevationMax;
//Ask the User for a Min and Max Elevations for the Profile View
// Ask the user for a minimum elevation
PromptDoubleOptions minElevationOptions = new PromptDoubleOptions($"\nEnter Minimum Elevation (Current: {profileViewMinElevation}): ")
AllowNone = false,
DefaultValue = profileViewMinElevation
PromptDoubleResult minElevationResult = edt.GetDouble(minElevationOptions);
if (minElevationResult.Status != PromptStatus.OK) return;
profileViewMinElevation = minElevationResult.Value;
// Ask the user for a maximum elevation
PromptDoubleOptions maxElevationOptions = new PromptDoubleOptions($"\nEnter Maximum Elevation (Current: {profileViewMaxElevation}): ")
AllowNone = false,
DefaultValue = profileViewMaxElevation
PromptDoubleResult maxElevationResult = edt.GetDouble(maxElevationOptions);
if (maxElevationResult.Status != PromptStatus.OK) return;
profileViewMaxElevation = maxElevationResult.Value;
//Upgrade to Write for changes
selectedprofileView.UpgradeOpen();
selectedprofileView.ElevationRangeMode = ElevationRangeType.UserSpecified;
//Check if Elevation range Mode has been changed before trying to change values
if (selectedprofileView.ElevationRangeMode == ElevationRangeType.UserSpecified)
selectedprofileView.ElevationMin = profileViewMinElevation;
selectedprofileView.ElevationMax = profileViewMaxElevation;
trans.Commit();
edt.WriteMessage("\nProfile view Elevations Updated!\n");
}//End Transaction
}//End Documentlock
catch (Exception ex)
Application.ShowAlertDialog($"Error Encountered: {ex.Message}");
}//End FucntionYou have to set Max value first, else Civil 3D might crash. I am not sure if that is your case but it was mine a while ago.
I have no issues setting the elevations. The issue is when getting the current elevations that isnt returning the correct values when selecting the profile view and reading the elevations.
