API MINIMUMDISTBETWEENSURFACES
Dexterel
Dexterel
Is MINIMUMDISTBETWEENSURFACES implemented in Civil API?
lu_an_jie
AFIK this command is not exposed in the .net API. I would approach it by creating the Volume Surface  with TinVolumeSurface.Create (...) and than analyzing this surface.  First check the Surface.GetGeneralProperties (...) for the MinimumElevation. If the MinimumElevation is greater or equal zero, than MinimumCoordinateX and MinimumCoordinateY gives you the point. If MinimumElevation is negative, than the surfaces crossing each other and you can create with SurfaceAnalysis.SetUserDefinedContourData (...) with elevation 0 the crossing lines and read them with SurfaceAnalysis.GetUserDefinedContourData.
Regards
Andreas Luka (Lu An Jie)
http://www.luka-consult.de
Creator of the LX-Stair App for Civil 3D
Dexterel
I already made the volume surface and used surface.ExtractContoursAt(0) and tested if the no. of contours is >0.
lu_an_jie
Does ExtractContoursAt(0) work at a TinVolumeSurface? AFIK the method is only on TinSurface available.
Regards
Dexterel
ExtractContoursAt works on TinVolumeSurface, TinSurface and GridSurface
