Alignment.StationOffset() Function in Excel VBA
csandersonGKMZ9
Message 1 of 9
csandersonGKMZ9
I'm trying to use the .StationOffset VBA function to find out the station and offset of a point in relation to an alignment, all within Excel VBA editor.
I know within the AutoCAD VBA manager you would simply write out:
Align.StationOffset x, y, station, offset
But the syntax doesn't seem to work within Excel's editor. The problem seems to be that the function gives two outputs and I'm not sure how to code for that within Excel.
Thanks in advance for any help
Replies (8)
Message 2 of 9
Jeff_M
Can you post your Excel file with the VBA? It's been years since I've worked with that so would take too long to set it up.
Jeff_M, also a frequent Swamper
Message 3 of 9
csandersonGKMZ9
Hi Jeff,
File is attached below, it assumes you have an active drawing with a Pipe Network in it, the spreadsheet is intended to deal with those in the end. I can write something quick dealing only with the alignments if needed.
Thanks for looking into this
Jeff,
Having problems attaching the xlsm file, I'll post the code below unless there's a way to attach the macro enabled file.
Sub Access_AutoCad()
Dim MyApp As Object
Dim MyDwg As AcadDocument
Set MyApp = GetObject(, "Autocad.Application")
Set MyDwg = MyApp.ActiveDocument
Dim oApp As AcadApplication
Set oApp = MyDwg.Application
Dim sAppName As String
'sAppName will need to change with 2020 to "AeccXUiPipe.AeccPipeApplication.XX.0" the XX being whichever
'version number 2020 uses.
sAppName = "AeccXUiPipe.AeccPipeApplication.12.0"
Dim oPipeApplication As AeccPipeApplication
Set oPipeApplication = oApp.GetInterfaceObject(sAppName)
 'Get a reference to the currently active document.
Dim oPipeDocument As AeccPipeDocument
Set oPipeDocument = oPipeApplication.ActiveDocument
'Creates set of Pipe networks Within the Drawing
Dim oPipeNetworks As AeccPipeNetworks
Set oPipeNetworks = oPipeDocument.PipeNetworks
'Establishes the Working Network
Dim WNet As AeccPipeNetwork
Dim K As Integer
    For P = 0 To oPipeNetworks.Count - 1
        If oPipeNetworks(P).Name = Sheet1.Cells(1, 23).Value Then
        K = P
    Next P
Set WNet = oPipeNetworks.Item(K)
Dim WPipes As AeccPipes
Dim WStructures As AeccStructures
Set WPipes = WNet.Pipes
Set WStructures = WNet.Structures
Dim PipeLim As Long
PipeLim = CInt(WPipes.Count) - 1
Dim StrucLim As Long
StrucLim = CInt(WStructures.Count) - 1
Dim stn As Double
Dim Offset As Double
Dim Align As AeccAlignment
Dim Wstruc As AeccStructure
Dim WPipe As AeccPipe
Dim WStrucX As Double
Dim WStrucY As Double
Dim PipeArray(0 To 400, 0 To 8)  As Variant
Dim StrucArray(0 To 400, 0 To 7)  As Variant
Worksheets("Sheet1").Range("A1:V400").ClearContents
        For j = 0 To PipeLim
             Set WPipe = WPipes.Item(j)
             PipeArray(j, 0) = WPipe.Description
             PipeArray(j, 1) = WPipe.Style.Name
             PipeArray(j, 2) = WPipe.InnerDiameterOrWidth * 12
             PipeArray(j, 3) = WPipe.StartStructure.Name
             PipeArray(j, 4) = WPipe.EndStructure.Name
             PipeArray(j, 5) = WPipe.StartPoint.Z - (WPipe.InnerDiameterOrWidth / 2)
             PipeArray(j, 6) = WPipe.EndPoint.Z - (WPipe.InnerDiameterOrWidth / 2)
             PipeArray(j, 7) = WPipe.Length2D
             PipeArray(j, 8) = WPipe.Length2D - WPipe.StartStructure.StructureInnerDiameterOrWidth / 2 - WPipe.EndStructure.StructureInnerDiameterOrWidth / 2
        Next j
        For w = 0 To StrucLim
             Set Wstruc = WStructures.Item(w)
             Set Align = Wstruc.Alignment
             WStrucX = Wstruc.Position.X
             WStrucY = Wstruc.Position.y
             'Set stn, offset = Align.StationOffset(WstrucX,WStrucY,stn,offset)
             StrucArray(w, 0) = Wstruc.Name
             StrucArray(w, 1) = Wstruc.Style.Name
             'StrucArray(w, 2) = stn
             'StrucArray(w, 3) = offset
             StrucArray(w, 4) = WStrucY
             StrucArray(w, 5) = WStrucX
             StrucArray(w, 6) = Wstruc.RimElevation
        Next w
Sheet1.Range("A1:G400").Value = StrucArray
Sheet1.Range("M1:U400").Value = PipeArray
End Sub
Message 4 of 9
norman.yuan
In your Excel VBA editor, have you added references to necessary Civil3D COM libraries (AeccXLandLib/AeccXUiLandLib, ... )? If you did, you should have been able to see in Object Browser, like:
Norman Yuan
Drive CAD With Code
Message 5 of 9
csandersonGKMZ9
I have them referenced, the error that pops up when I try to run the function is "Compile Error: Expected function or variable". This is making me think its a difference in the syntax between the VBA in excel and Autocad. The StationOffset function gives two outputs and I'm not sure how to set two variable values at once in the Excel VBA.
Message 6 of 9
Jeff_M
If you ZIP up a file you should be able to post the ZIP file.
I'm assuming this is the line giving you problems:
This should work:
Dim stn As double
Dim offset As Double
Then the 2 variables will contain the values obtained from the alignment.
Message 7 of 9
csandersonGKMZ9
I tried that solution and get a Syntax Error when I try to compile.
I attached the zip file below, there might just be a simple syntax fix that I am missing but I haven't been able to assign both variables values at once.
Message 8 of 9
norman.yuan
This should work:
Dim stn As double
The red line should be (no bracket, we have left VBA long enough to be not used to that kind of strange syntax):
Align.StationOffset WstrucX, WStrucY, stn, offset
Norman Yuan
Drive CAD With Code
Message 9 of 9
csandersonGKMZ9
That worked perfectly, thank you both for your help
